BAD backfire HELP!!!
delldoe
So hears the deal, pulled out onto the highway and smashed it 1st through 3rd and right as I let the clutch out into 3rd my car started backfiring real loud. "sounded like a shotgun going off" turned the car off and coasted off the road. Now it won't even start and is backfiring through the intake exhaust. got a po340 code which is for the camshaft position sensor. Put in a new one, still won't run. changed out the crankshaft position sensor and have same results. Has anyone had this happen to them??? let me know what you think
:shrug: I have no idea man.. but if you figure it out... please share with us.. Cause that is the strangest thing ive ever heard. good luck on it:nice:
I didn't experience the way you got to your problem, but I had one of the many 2002 alternators that died an early death...fortunately got it replaced under warranty. They also swapped out my battery for free...
I think I might have had the same kind of problem. The code kept coming up and said crankshaft position sensor. I was pulling my hair out trying to fing out what it was and it ended up being the wiring on the CSPS ( the connector to be exact ) was the slightest bit loose and woulld make good contact sometimes and sometimes not, but while I was serching for this problem I talked to quite a few mechanics and bad coils could also cause this or (1 bad coil, 2 bad, 3 bad ect.) I could only get the car to rev to about 5300 rpm then it would backfire between 5300 and 5900, never got it to go past 5900 ( professionaly built motor to rev to 7400 rpm ) and my boost was all f'd up on the street when under a load. I would mash the gas and it would sputter, backfire and a couple times even shut off, but it would always restart easy. Havent had it tuned again since weather is bad now but we had 1 nice day and I took it out fora ride after fixing the connector and it ran great with full boost and no hesitation at all. But it took me about a month or so to track it down I tried all diffrent things. but just remember if it isnt the connector it CAN be a bad coil or so. I did tons of reserch on this. Hope this helps. Here is a vid of my car on dyno backfiring at about 5900rpm
http://www.youtube.com/watch?v=Ol3v0eDIH7E
