Just got done searching, and I think I may be mis-diagnosing my problem, any help is appreciated.
Problem: My clutch pedal vibrates real bad. You can hearing a loud knocking noise coming from the clutch for about 5 seconds, then stops for two seconds, and starts again. I've removed the dust cover where the clutch cable hooks up (It actually rattled halfway off) and - with the engine running - you can see the clutch partially engage by itself when the knocking noise occurs. The fork actually moves a couple of inches for those 5 seconds, then stops for 2 seconds, and so on...
Solution: I think it's the throw out bearing, but I'm not sure if its that or the shaft on the front of the tranny (t5)
My setup: I was on mile 2700 after putting in a new Spec Stage 1 clutch, pressure plate and throw out bearing (it was not one of the old Spec composite throw out bearings) MM Cable, Quadrant, Firewall adjuster.
My real problem is that I have to use my dads garage to do this in and I only have like a 2 day window, so I'm not sure which part to order. I'm hopeful someone has had this same problem so I know where to throw what little money I have at.
