bad computer?
  • Thread starter Thread starter bcd
  • Start date Start date Jan 25, 2006
bcd
274
arab al
Jan 25, 2006
  • Jan 25, 2006
Alright I pulled my wiring harness ,traced every wire, and repaired all problems.
I put it back in yesterday and it still doesn't run right. Still missing here and there. So i set the timing to 14* and then to 10* no help. So i decided to check the timing with the spout in just to see what it was doing. The line was jumping back and forth and some times the (when it was bogging) the timing light wouldn't even flash.
bcd
274
arab al
Jan 25, 2006
  • Jan 25, 2006
someone give me something before i set it on fire
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 25, 2006
  • Jan 25, 2006
The missing pulses say that your ignition isn't working right. Please give us a recap on what you have done in the ignition area.
bcd
274
arab al
Jan 25, 2006
  • Jan 25, 2006
its all stock replacement. but i have put a new tfi on it a new distributor new coil new wires new plugs new cap and button. it doesn't miss the pulses when the spout connector is out. on trickflows website it says i need to modify my mass air for my cam. what does that mean? and would that cause these problems?
bdazzgt
I had to jerk off the cable to get it to stop.
Dec 27, 2005
328
Springfield MO
Jan 25, 2006
  • Jan 25, 2006
it could mean that you need to drill a little hole in it to keep it from surging. just a thought
bcd
274
arab al
Jan 25, 2006
  • Jan 25, 2006
ttt
joel5.0
429
Puerto Rico
Jan 25, 2006
  • Jan 25, 2006
Have you run a KOER/Cylinder Balance self-test?...Recommend you run a few to check for specific "weak cylinders" or, if it is a random misfire issue. Also to check if a PIP or SPOUT signal failure is recorded as well. LUK(=Let Us Know)
bcd
274
arab al
Jan 25, 2006
  • Jan 25, 2006
i check the spout connector it shows a direct short. also put dielectric grease on it just in case. the computer wont run self test. fuel pump just primes twice then clicks a couple of times then nothing
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 25, 2006
  • Jan 25, 2006
Before you can chase the current rabbit, you need to fix the no computer codes problem. Dumping the codes would provide a great deal of useful information.
bcd
274
arab al
Jan 25, 2006
#10
  • Jan 25, 2006
  • #10
yeah i know, im thinking though that with the combination of the no codes and the current problem that i might have a fried computer. i am going to go throught the no codes checklist from the ford fuel injection website probably sunday, or when i can get my hands on a digital multimeter. no codes is the reason i pulled the harness and checked everything. is there an aftermarket ignitions system that lets you set the timing advance without the computer messing with it?
joel5.0
429
Puerto Rico
Jan 25, 2006
#11
  • Jan 25, 2006
  • #11
Definetely have a problem there...check VREF (5vdc) at the TPS connector with TPS disconnected to the SIGRTN wire/pin, Key On Engine Off. If you need to id the wires, use one of these diagrams. If you don't get 4.85vdc minimum, check VREF to a good ground and LUK.
bcd
274
arab al
Jan 26, 2006
#12
  • Jan 26, 2006
  • #12
i will give that a try
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
