  • 1994 - 1995 Specific Tech
Bad day...bent pushrod and valve...need help!
  • Thread starter Thread starter Chris_Red_V8
  • Start date Start date Apr 22, 2007
C
Chris_Red_V8
95
Scottsdale, Az
Apr 22, 2007
  • Apr 22, 2007
I've never had luck this bad. A friend was bringing my car to me, (I have some licensing issues that will be resolved Tuesday when the local DMV is open, and I don't want to risk anything until then), and he calls me and says the motor is making an awful noise.
My girlfriend brings me to where he is, and the noise is godawful knocking. We had some basic tools on site, and I took off the driver's valvecover, foud some marring on the inside of it, and when I went to match the mar to which rocker (they all were bolted down ok). When I saw the rocker, the spring was uncompressed, the retainers were laying in the head, and the spring topplate and insert were laying outside the spring as well. The pushrod was bent at least 1/8" outwards, and the valve stem was showing at least an inch out of the head, but it wasn't moving anywhere.
Pending my teardown tommorow to get the head off and also check the other valve cover, what should I be doing? I've never had a motor go boom on me like this... I am building that 351W block, but I am no where near completion, and I am not going to go cheap and get it built asap and be stuck here again in a year. At this point I just want to get the car back on the road as soon as possible as cheap as possible to make it safe until I can finish my 351W project.
So, if I am lucky, could I be out a valve, guide, some machining on the head, pushrod, other valvetrain parts, headgasket and headbolt (and intake gasket)? Or is it likely I've got lower end issues as well? What about my cam?
The engine was a GT40P head with the GT40 valvetrain kit, E303 cam, stock 95 longblock. Stock rockers as well.
I could just kill my buddy who was bringing it to me, but who knows, I guess it could have been a preexisting issue (tho I really think it was high-rev valve float)
Also, I may just ship the car out to Scottsdale now and just work on it when I fly out on the 12th. I'm not sure what the best route is, though I really need to accellerate my plans on getting the 351W done.
reddy351
560
12
38
Columbus, Ohio
Apr 22, 2007
  • Apr 22, 2007
I have to say that it sounds like he was beating on it a little. The parts that you mentioned are all really good ones. They'd have to be put together wrong, for that to happen, I would think. Don't let him drive any more of your cars.
You could just drop another Explorer longblock in there.
chaos254
467
NJ
Apr 22, 2007
  • Apr 22, 2007
i vote to kill your friend...this is why I don't let other people drive my car. Even if he really wasn't beating on it, I'd rather be the one to break it and know for sure why it went!
i would tear it apart and see exactly what kind of damage was done... then go from there. Hopefully you can rebuild it for fairly cheap.
Adam95GT
2,564
Burlington, NJ
Apr 22, 2007
  • Apr 22, 2007
where are you from ill look around for a cheap engine
go-stang5.0
2,244
Glenview,Il
Apr 23, 2007
  • Apr 23, 2007
If the valve doesnt move its prolly stuck in the guide....and thats prolly damaged too. If the valve guide is damaged this is gonna ge expensive in a hurry. Plus you dont know the condition of the piston either...cuz it is prolly hitting the valve. This isn't looking good.
On a side note..I lost my last motor like that. But for me the spring broke and the keepers came off at 6200 rpm...needless to say the piston ended up in the oil pan (in many pieces) and much of the connecting rod made it onto the expressway....but I digress.
Hopefully your piston is ok...but it looks like a decent amount of head work is in order.
C
Chris_Red_V8
95
Scottsdale, Az
Apr 23, 2007
  • Apr 23, 2007
I'm in Pensacola, Florida.
I'm hoping I the damage is contained to the head, but who knows. I heard even VatoZone sells GT40p heads with a core, I wonder how much that would run, though I doubt I'd ever trust the valvetrain components on it.
thumper460
3,022
Orange Park , Fl
Apr 23, 2007
  • Apr 23, 2007
Yep... sounds like some one pushed the engine hard and the valve foated and kissed a piston.. or the GT40 Spring broke!! Get the head off and check the piston for damage.. if the piston is OK, then AZ sells heads for the "explores" Yep GT40s!! and I believe guys are snagging them for 450 or so.. then upgrade the springs with a performance set.. and put it all back together. If the MONEY is there .. should take a day or two. Key point.. up grade the springs..
Have fun..
Just me.......................................
Thumper
C
Chris_Red_V8
95
Scottsdale, Az
Apr 24, 2007
  • Apr 24, 2007
Have fun..
Thumper
Well, I lucked out. Was valvespring float, I'm getting new crane springs (supporting 575 lift and 6500rpm), pulled both heads which are being repaired and ported (I didn't want to since I am building a new motor, but was sold on it when I saw the price and some examples from his flowbench.)
Going to cost $500 when everything is said and done to get the heads remachined, ported, the new springs, retainers, keepers, gaskets, bolts fluids etc. Just a bummer to have to clean the block again and all this labor I have to put in the car, but happy to know what the problem was (which apparently has been a problem for some time, see dynograph in sig), and that I'll be picking up a bit of power as well.
thumper460
3,022
Orange Park , Fl
Apr 24, 2007
  • Apr 24, 2007
Yikes..!! we all need to go to that shop... $500.00 for ALL that is stealling LOL!!
Have fun..
Thumper
ProKiller
3,064
15
78
PA
Apr 24, 2007
#10
  • Apr 24, 2007
  • #10
good to hear you'll get it running again. and that price is amazing.
C
Chris_Red_V8
95
Scottsdale, Az
Apr 24, 2007
#11
  • Apr 24, 2007
  • #11
Have fun..
Thumper
Lucked out a lot there because its parts that had been on the shelf for some time, and the machinest hasn't had a ford engine of his own for a long time (IE the valve springs are running me $40 new). Also thankfully, he doesn't subscribe to the "hog out every runner" theory a lot of local porters seem to subscribe in this area. Mostly clean up the transitions on the exhaust side with a lot of bowl blending and the bottom side of the exaust port. Intake ports would be gasket matched and bowlblended again.
Piston has a bit of a stamping on it, but I hope I am ok there, turned the motor over by hand, and the piston still comes all the way up, straight and inline with the deck, no evidence of rod issues that I can tell. Turns over fairly easily.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
T
408w pushrods
  • Towegage
  • Sep 19, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 19, 2025
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
