I'm hoping I can reuse my top end and either replace or rebuild my bottom end. Once I pull the valve cover and drain the oil I hope to know more.That flat tappet motor is a step backwards, right? Your crap may be fixable.
Yeah, that would be me.A great suggestion sir, but:
= pass.
Wasn't that you that went on a rant with me a while back about the stupidity of using flat tappet cams after our motor oil got hosed by the gubment and the zinc is removed, which leads to quick and certain death of all flat bumpsticks???
I always got that one with a short open wrench
It's 3/8. I got the one in front with a 3/8 12 point midget wrench but I can't get it on the back. None of the sockets I have are thin enough. I ran to Lowes but they didnt have much either. I'm going to try a few other stores tomorrow. This is the only thing preventing me from getting the upper off.what size nut is it?
Try a snap on socket or a 12 point distributor wrench
Bottom end should be fine, check the oil.After I used a grinder to trim down my box wrench I was able to get that last nut off and pull the upper intake. When I removed the valve cover I found that the stud that holds one of the rocker arms for cylinder #6 had sheared off so the rocker arm was smacking on the inside of the valve cover. My question now is, where do I go from here? Does the head need to come off for this to be repaired? Could this have caused a problem with the bottom end as well?
Have you drained your oil to see if there is anything other than oil in there? How does you push rod look?
