BAD misfire problem, cant figure it out...
VG30DE
364
Dudley, MA
Both my notch and my buddys 97 ranger (95 cobra motor A9L T5 swap) are doing the same crap. Both started doing it last week.
Idle- fine, no surge, no stall, no misfire.
Rev it up.... insane amounts of popping, smoking (way too rich), gets worse as you get higher in rpm's and worse more if you throttle into it. No balls at all in gear. Absolutely cant figure it out. Both vehicles were filled up at the same gas station and kept at the same place.
Ranger - no egr, no O2 sensors. has been like this for years, always runs well.
replaced:
fuel pressure regulator
fuel filter
fuel pump
tps
maf
tfi module
Notch - no egr, always runs well.
replaced:
O2's
turned boost and fuel pressure up and down
ran 3 tanks of fuel through it running like ass
Only things I'm thinking are bad EEC or bad fuel, but I filled up my wrx from the same place same pump and its running fine.....
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
