Bad P/S pump?
  • Thread starter Thread starter interceptor7
  • Start date Start date Feb 26, 2008
I
interceptor7
59
  • Feb 26, 2008
The P/S pump in my 93 GT started whining VERY loud recently. Basically whenever the steering wheel is not at "dead-center", it whines. It gets worst at the end of the travel.
I'm assuming the P/S is the culprit. Where's a good place to buy one from so I don't have to pay $120 from CJ Pony Parts? I don't want one that will break in 6 months, either.
Thanks
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 26, 2008
  • Feb 26, 2008
http://forums.stangnet.com/showthread.php?t=701655
N
n2o-89fox
116
ca
Feb 26, 2008
  • Feb 26, 2008
Autozone lifetime warranty
mazroth
56
KY
Feb 26, 2008
  • Feb 26, 2008
You sure there is fluid in there? They will whine when low.
Where are you located, try a local stang site if there is one. I could post on a few boards in my area and probably come across a few. I even have my old one in the garage still from going to a manual rack.
Fast63
717
  • Feb 26, 2008
always check the fluid first. Ford P/S systems are inferior to other companies, and are more prone to leaks and failures. Could be you have a slow leak somewhere so top off the fluid and see what happens
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 27, 2008
  • Feb 27, 2008
Also make sure you use Type F Fluid Only!!!
Maryland Stang
1,656
30
39
Greenville, NC
Feb 27, 2008
  • Feb 27, 2008
The flow control valve strainer may be plugged too. It's easy to check. Remove the high pressure hose from the pump. Remove the fitting from the pump. The flow control valve is right under the fitting and there is a medium sized spring right behind the flow control valve. The spring shouldn't come flying out but I just wanted to let you know it was there so you don't loose it. Anyway, remove the flow control valve and see if the strainer is plugged up. You may want to replace the two O rings there. There is a power steering O ring kit available everywhere for under $10 that has the correct O rings. Then put the everything back together and tighten the fitting to 30 ft lbs.
I
interceptor7
59
  • Feb 27, 2008
Thanks for all the responses.
I haven't checked the fluid b/c there were no signs of leaks. I'll go ahead and check it anyways.
Thanks again!
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
