  • 1994 - 1995 Specific Tech
Bad shake
  • Thread starter Thread starter wlink1
  • Start date Start date Aug 27, 2007
wlink1
Banned
Apr 12, 2007
69
Winston Salem
Aug 27, 2007
  • Aug 27, 2007
My car has a really bad vibration when at idle, doesn't make a difference if in park or in neutral, still shakes. Didn't know if anyone had any sugestions. Also car seems not to have the reponse it did before this problem started. The only thing I could think of was motor supports or trans supports? Any info would be appreciated
bmac50
123
Florida
Aug 27, 2007
  • Aug 27, 2007
Have you checked the motor mounts?
wlink1
Banned
Apr 12, 2007
69
Winston Salem
Aug 27, 2007
  • Aug 27, 2007
no physical inspection yet but checked while holding the brake in drive and reving and no out of the ordinary twisting of the engine, going to check my HB as I found alot of people with the same problem. Thanks also looked at the trans while idling and doesn't seem to be moving at all
HISSIN50
34
129
Aug 27, 2007
  • Aug 27, 2007
Agreed on checking the balancer.
Good luck.
wlink1
Banned
Apr 12, 2007
69
Winston Salem
Aug 27, 2007
  • Aug 27, 2007
thanks it was the HB changed it out tonight and it was starting to seperate
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Aug 29, 2007
  • Aug 29, 2007
Good thinking! I sell 302 ad 351 balancers quite a bit at my store.
Zero_chance
1,244
Maricopa, AZ
Aug 29, 2007
  • Aug 29, 2007
I just diagnosed my rough idle finally and it was the balancer. I kept thinking ignition components and then I did a 4 liter Mountaineer balancer at work because of the same exact symptoms... Then I go home and sure enough, rubber crapped out on the balancer. Now I just need to find a replacement...
WHITE94COBRA
816
HUNTINGTON BEACH
Aug 29, 2007
  • Aug 29, 2007
Buy a good quality replacement, I changed out 3 stock replacement one's now.
wlink1
Banned
Apr 12, 2007
69
Winston Salem
Aug 29, 2007
  • Aug 29, 2007
I got the Pioneer industries from Advance I read a couple other people used that one and had no problems. Probably change to a Romac or Heavy Duty one once I put the turbo set up on still trying to piece it together
gcomfx.com
3,690
Republic, MO
Aug 29, 2007
#10
  • Aug 29, 2007
  • #10
x2 Stock balancers don't last.
Zero_chance
1,244
Maricopa, AZ
Aug 30, 2007
#11
  • Aug 30, 2007
  • #11
Im building a 351 over the winter and Ill only be driving the car another month or so so Im probably just going to get a stock replacement through work and save the extra money and put it toward the 351. Ive heard that the stock ones are a little less than quality. Just cant justify spending two hundred dollars or more on one for a months worth of use, ya know.
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
K
Severe Drivetrain Shaking
  • KeithM412
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 29, 2025
AeroCoupe
