  • 1994 - 1995 Specific Tech
bad squeak
  • Thread starter Thread starter gtstang86
  • Start date Start date Nov 8, 2007
gtstang86
55
California
Nov 8, 2007
  • Nov 8, 2007
so ive had this bad squeak coming from my rear passenger-side wheel well. Originally i thought is was the brakes. the pads as well as the calipers were replaced but the squeak is still present. it will start to squeak when i get up to about 30 miles per hour or make a right turn. the squeak does stop when i apply the brake. any ideas on what it could be??
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 8, 2007
  • Nov 8, 2007
could be an outer axle housing bearing
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 9, 2007
  • Nov 9, 2007
Another vote for the axle bearing. Your tire isn't rubbing on your tailpipe at all is it?
gtstang86
55
California
Nov 9, 2007
  • Nov 9, 2007
no its not rubbing the tail pipe. would i need any special tools to replace the bearing? i guess i should look at my haynes.
1TallMF
955
Montreal
Nov 10, 2007
  • Nov 10, 2007
This might be a long shot, but I had a simiar sound coming from my driver's side rear, I thought was the brake pads or something like that, but after more thorough inspection, I noticed an area on the tailpipe where the upper control arm has been rubbing the tailpipe, removing the aluminized coating and thus creating a small rust spot. Have a closer look to see if your tailpipe(s) is(are) rubbing the UCA's at all, the sound it makes on mine is more noticalbe on smooth pavement where there are only very small surface variations and the suspension moves maybe a couple millimeters at a time. It drives me nuts, but I'll be putting either dumps or side-exhaust on the car after the winter.
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
