bad vibrations
  • Thread starter Thread starter 1967coupe
  • Start date Start date Dec 3, 2004
1967coupe
109
Wausau, WI
Dec 3, 2004
  • Dec 3, 2004
Recently I installed a T5 and then took it to a shop to have my new rear installed. Everything is new or freshly rebuilt, except the axles. After they put in the rear and went for a test drive they noticed a vibration at approx. 55 mph on up. I had them take out the driveshaft so I could have it spun again to make sure it was OK and it is. Pinion angle is correct as well. They think one of the axles may be slightly bent. What do you guys think?
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Dec 3, 2004
  • Dec 3, 2004
Could be a bent axle. Have someone follow behind you, if it's bent significantly they will be able to see a wobble.
Have your wheel ballance checked also. I know you didn't do anything with rims/tires, but you never know. Could have lost a weight or something during the whole process.
2nd Mustang
2,488
Southern California
Dec 3, 2004
  • Dec 3, 2004
Is the vibration present when you're on the gas or off the gas or both? If the vibration is while you're on the gas, most likely a driveline problem. I had a similar problem on my automatic Camaro. It was my tranny causing a vibration at certain speeds only while on the gas. I went through the alignment/balance thing first to no avail.
1967coupe
109
Wausau, WI
Dec 3, 2004
  • Dec 3, 2004
It's both but disappears when the speed decreases.
1967coupe
109
Wausau, WI
Dec 6, 2004
  • Dec 6, 2004
I got my car back from the shop on Sat. (not done yet but I kinda had to cause we got a few inches of snow today) and took it home. Once I hit about 50 the whole car starts vibrating and gets worse as the speed increases but goes away after the speed drops down. I'm beginning to think that the 3rd member has a bad bearing or was just plain rebuilt incorrectly. I don't know a whole lot about rears. Anyone have any other suggestions?
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
