Bad Vibrations
  • Thread starter Thread starter KillerKittyCat
  • Start date Start date Dec 7, 2004
KillerKittyCat
150
Hammer Down - Behind The Wheel
Dec 7, 2004
  • Dec 7, 2004
1965 A block 4 speed.
Replaced the rearend with an Auburn about 18 months ago. Replaced the clutch and u-joints about one year ago.
When I begin to drive I get horrible shaking and have to ride the clutch. In any gear I occasionally have to push in the clutch to eliminate the vibration and the car is smooth after that.
Clutch going bad was my first thought, but I think it might be the tranny. It is original with 345,000 miles on it.
Ideas on how to identify what is going on before I tear the car apart??
rbohm
6,698
550
204
tucson,az
Dec 7, 2004
  • Dec 7, 2004
when you replaced the clutch, did you replace the pilot bushing? if not, that and a worn input shaft bearing can cause a vibration as they would conspire to allow the clutch disc to fall off center when shifting.
SandSprite
332
L.A., CA
Dec 7, 2004
  • Dec 7, 2004
Sounds like clutch chatter. Was the flywheel resurfaced when you replaced the clutch? Did you put thread sealer on the crank/flywheel bolts?
KillerKittyCat
150
Dec 9, 2004
  • Dec 9, 2004
This is what I am thinking. The pilot bearing seemed okay but it was a quick clutch replacement. Had to replace the clutch due to a collapsed spring.
Flywheel was okay, smooth as a baby's butt and well within spec. LocTite on all bolts.
I guess I learn to rebuild a T-10
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
