- May 26, 2004
- 162
- 0
- 0
I just installed the baer rear 13" brake kit. Everything cleared and it was fine, then I took it for a drive. Im having problems, the bracket that holds the caliper is grinding onto the edge of the rotor. I have no idea why. It smells so bad and its heating up and peeling the endings off the rotor. Are the slider pins frozen?? They moved in and out, but that wouldnt cause grinding from actual bracket on rotor. Also brake pads are scoring the rotor. Ths kit was made horrible, why do i have problems. Did putting the wheel back on and tightening it make something move? I heard a little grinding when I backed the car up, but I thought everything just needed to be broken in, but I knew it wasnt right. Also car seems like its slowing down not moving freely. Any of this have to do with the ebrake cable being so tight and extended to fit in, since moved outward more?
