baer brakes
Baer kit ordered.
I have a 66 with 17's and have ordered the 13" kit for the front and the 12" for the rear. Since you are in Brunswick (60 miles) you can come observe the installation:rlaugh: . They said it would be 4-6 weeks which should be about the timetable I need to get the rest of the car done. On a serious note they said I shouldnt have to buy anything to install them and I will post pics here as soon as I am done. I do have a set of Grananda fronts and Versailes rears that I just had powdercoated red if any one is interested?
I ordered a set of the 12" for the front on my 70. everything went on without a hitch. The kit comes with everything accept hard lines. It had two adapters to fit different brake line sizes on the body. brackets bolted right up and so did the mc. You'll prob have to make new brake lines or re route them as the exit ports on the new mc (94/95 stang unit) are on the opposite side of the stocker. It comes with two lines with a bubble flare already to do this.
Hope it helps
send me ur phone # i go to school at otc in waycross were on spring break but i have to and register in a couple of weeks!
let me know when u get them ill come and help my fastback is in waycross im tryin to get mine driving for summer ive got to do brakes suspension interior and get it running and figure y my toploader will not go into gear?a toploader rebuilding company at the moultrie car show told me to take the top cove off and try to move the gears manually to make sure none of them are seized cause it could be stuck in 2 gears? butmy shifter is in the neutral position!
I have the 13" front and 12" rears on my 71. Install was very straightforward and went without a hitch. I have had them for about one year now and when I ordered they were here within a week. I understand there is now a long wait due to more demand. I used their master cylinder and prop valve included in the kit and it worked fine. I also ordered their bump steer kit as well and that is one well made product.
