Baffle for Factory Valve Covers?
  • Thread starter Thread starter allballsmustang
  • Start date Start date Jul 3, 2007
allballsmustang
174
Lehigh Valley, PA
Jul 3, 2007
  • Jul 3, 2007
Anyone have some pics of a baffle that they fabbed up for their factory valve covers to clear roller rockers?? I was actally thinking about using a piece of screen... any suggestions?
jim
cenok is family
1,409
69
79
Norman, Ok
Jul 3, 2007
  • Jul 3, 2007
i just took mine out completely...
allballsmustang
174
Lehigh Valley, PA
Jul 3, 2007
  • Jul 3, 2007
did you connect the hose that goes to the throttle body back up or did you just use a regular breather on it?
mustanggt5pt0
34
Cedar Falls, Iowa
Jul 3, 2007
  • Jul 3, 2007
I just took the baffle off and then pounded it flat. I put the valve cover back on and checked to see where it was hitting and then used a dremel to give enough clearance. I also had to use an angle grinder to remove extra casting material from the sides to make mine fit.
cenok is family
1,409
69
79
Norman, Ok
Jul 3, 2007
  • Jul 3, 2007
i put the hose back on for now. i'll probably go with a breather later on though seeing as theres no longer anything stopping oil from going up the filler neck and hose anymore.
9
91notchbk
163
Jackson Michigan
Jul 3, 2007
  • Jul 3, 2007
Hi Jim,
I went through this dilema when I built my motor. I first removed the old baffle and ground material away and made a new baffle and reattached it by drilling some new holes and using self tapping screws. This worked but I was nervous about the screws. Even though I used loc-tite I thought if one came loose it would destroy the motor.
So I finally decided to make a small cover out of sheet metal and weld it to the bottom of the oil-fill tube. The oil-filltube is steel so it will work. One problem I ran into was I already hade painted the valve covers (base coat/clear coat) so welding may ruin the paint. I was able to use a mig welder with and make small short spot welds. After each weld I used the rags soaked in water to cool the cover to prevent hurting my paint job. Also, the metal on the bottom of the oil-fill tube is thin so only short spot weld will work or you will blow through the metal. I was able to get this to work sucessfully even with new paint on the cover. I smoothed the welds out with a die grinder after I was done.
Here is a pic of the completed baffle. You can still see the holes I drilled.
Good luck.
https://home.comcast.net/~perkin50/DSC01341.JPG
My car. https://home.comcast.net/~perkin50/index.html
allballsmustang
174
Lehigh Valley, PA
Jul 3, 2007
  • Jul 3, 2007
91notchbk said:
Hi Jim,
Good luck.
thanks for the help...i just went out to the garage and made one like you have and it seems like it should work...just out of curiosity what rockers are you using? how much clearancing did it require on the sides of the valve cover?
9
91notchbk
163
Jackson Michigan
Jul 5, 2007
  • Jul 5, 2007
I have the scorpion 1.6 RRs. There was not alot of clearance on the sides but they did not rub. To be safe I made some extra clearance.
H
1995 cobra engine noise help
  • Holt2010
  • Nov 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 8, 2026
Holt2010
H
Wheels-Tires Factory white ponys, anyone know a color match paint for them?
  • rednotch
  • Apr 26, 2026
Fox 5.0 Mustang Tech Apr 27, 2026
rednotch
A
Engine Genius installed oil filler above rocker arm…
  • afjLX
  • Mar 27, 2025
Fox 5.0 Mustang Tech Mar 29, 2025
nicholase
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
