  • 1994 - 1995 Specific Tech
Balancer help
  • Thread starter Thread starter 95vert354
  • Start date Start date Mar 19, 2006
9
95vert354
107
  • Mar 19, 2006
Working on a stroker build, and need any input on a balancer/flywheel selection. Engine is a 5.0 stroked to 354 with 4340 eagle crank with internal balance.Looked at ATI and Romac balancers,but both of them were listed to fit '86-'93, I'm putting this in a 95 vert with tremec 500.Is the '94 -'95 balancer different?Is a spacer used for '94 -'95 applications? I was told the '86 -'93 model won't clear the timing cover. The car wont see much track time,so I won't be pushing it past 6000 rpm that often, but I want a decent product in case I do some mods later, I wont have to worry about it holding together. Any help would be appreciated.
RIO5.0
6,892
N.H.
Mar 19, 2006
  • Mar 19, 2006
I run a Romac...Only dif is 50oz imbalance for our SN95s vs 28oz for the Fox years...and your motors balanced to what??? I needed no spacers or the like...
9
95vert354
107
  • Mar 19, 2006
Motor is internal 0 balance. I was looking at the frpp balancer online and they stated it wouldnt clear the timing cover on '94-'95. I guess the romac is shorter than the frpp. just want to make sure it fits with serp pulley/belt. where did you get yours from? price?
95CobraMike
1,046
Lima OH
Mar 19, 2006
  • Mar 19, 2006
i run a romac, 50 oz.......not sure about what to do if your are 0 balanced...
RIO5.0
6,892
N.H.
Mar 19, 2006
  • Mar 19, 2006
No problems on clearance on the timing cover for the Romac....Never heard it being an issue....
I got mine thru Corral classifieds...Someone stepping up...Had only a few 1/4 miles passes on it..
69clark
731
Ravena, NY
Mar 19, 2006
  • Mar 19, 2006
I also run the Romac on mine. I bought the 50oz imbalance and no clearance issues. Not sure if it was 94-95 specific or not. But I had no issues.
9
95vert354
107
  • Mar 19, 2006
Thanks for the help. Found a romac on e-bay new in box $259.
I didn't mean there was an issue with the romac with regards to clearance, just that frpp said theirs wouldn't clear on '94,'95. My builder suggeted ATI balancer, but it's another $100 more than the romac. I'm getting toward the end of the build and $'s are getting tight.
Thanks again for the input guys.
69clark
731
Ravena, NY
Mar 19, 2006
  • Mar 19, 2006
I think I paid about $350 when I bought mine. I shopped around too. That sounds like a good price.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 20, 2006
  • Mar 20, 2006
Fox 302's are the same as the 94/95 302's. All 50oz external balance.
I sold my old 50oz Romac I had on my car to a dude with a 94/95. I like the lightweight romacs but they will get some surface rust on them in some spots. They also fit VERY tight on aftermarket crankshafts. I had a hell of a time putting my 28oz romac on my scat crank!
If you have a 0 balance motor, you run a 0 balance balancer Hands down use a romac over a frpp balancer.
9
95vert354
107
#10
  • Mar 20, 2006
  • #10
Thank's guys, bought the romac,$259 and free shipping.....now for a flywheel Aluminum? billet steel?
What are the pros and cons of aluminum?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 20, 2006
#11
  • Mar 20, 2006
  • #11
Did you get the steel romac or the light weight steel/alum romac? Hopefully the light weight unit.
And you want an aluminum flywheel. Faster acceleration, faster rev's, less wear and tear on your crankshaft. Love mine
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Mar 20, 2006
#12
  • Mar 20, 2006
  • #12
i would go with a romac balancer and a fidanza flywheel. it is the combo i have had on both of my stangs for years with no problems. it isnt the cheapest combo to go with but in my eyes it is by far the best.
9
95vert354
107
#13
  • Mar 20, 2006
  • #13
Yes, it is the aluminum outer ring, light weight Romac. I'm going to hold off on the flywheel for right now until I get the old motor out and see what the previous owner(just bought the car last month) had installed on it. He told me he put a Zoom kevlar clutch in about 4k miles ago. IF it has removeable weights and is in decent shape ,I'll just stick with it, be it steel or aluminum. I sure appreciate all the suggestions, thanks.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
E
Fox Water Pump and Timing Cover on 95?
  • eglick125
  • Apr 1, 2024
1994 - 1995 Specific Tech Apr 30, 2024
85GTStangGuy
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
