balancer issues
  • Thread starter Thread starter hatchback88
  • Start date Start date Jan 18, 2011
hatchback88
24
  • Jan 18, 2011
so im new in the fox body world and starting a build.I have a 88 hatch that i just bought and after 3 weeks of owning it the head gasket popped, so i picked up a motor out of a late 80s crown vic stripped it down and sent it to the machine shop.I plan on using the stock crank but i dont know if it is 28oz or 50oz imbalanced if someone knows your input would be great also anyone ran patriot 185s thanks
stykthyn
5,232
2,652
223
gainesville
Jan 18, 2011
  • Jan 18, 2011
50oz and avoid the patriots.
stykthyn
5,232
2,652
223
gainesville
Jan 18, 2011
  • Jan 18, 2011
The balancer from the crown vic will work if its still in good shape.
faststang90
522
baytown texas
Jan 18, 2011
  • Jan 18, 2011
was it a roller block.
hatchback88
24
  • Jan 19, 2011
it is a roller block i just need to use the crank and block for the start of the build, when you say stay away from the patriots is do the the hardware they build them with or just the whole casting
stykthyn
5,232
2,652
223
gainesville
Jan 19, 2011
  • Jan 19, 2011
Lots of casting issues
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Jan 19, 2011
  • Jan 19, 2011
A new ford racing balancer is only $85, buy new.
Heads, TW's, gt40x, edelbrock rpm, or afr 165's would be good choices.
hatchback88
24
  • Jan 19, 2011
i dont plan on reusing the balancer i just wanted to make sure it was the same crank weight as what is in the car now but on the heads im debating on assembled or bare casting and build them around the cam i choose what would be the best out of the box im guessing the afr's
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Stripped Crank threads and cracked Crank Shaft Ring at end (what is it called?)
  • 69machmike
  • Nov 13, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 19, 2024
89ripper
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Betty white budget build
  • Stevenmverrill
  • Jun 16, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2023
2Blue2
