Balancer
FordGuy88
241
Park Ridge, IL
What is the stock oz balancer? I want to say it is 50 oz, but I am not 100% on that. So please correct me if I am wrong. Also I was thinking about buying a new balancer. If it is the stock oz then can I just slap it on, or what do I have to do.
Thanks,
Dave
Up until 1981 (?) the 302 was 28oz imbalance and then after that it was switched to 50oz. If your motor is newer than 1985, to be safe on the year of the switch, and it's stock it will be 50oz. imbalance.
You will need a pully puller and a balancer puller. Both of those can be picked up from the local autoparts store.
A pulley puller??? Why would you need that? I changed mine last night, I took out my stock fan and shroud (obviously belt too), Loosen the balancer bolt, I just put it in reverse and ebrake up and it was good enough, Take out the 4 bolts that hold on the pulley which then comes right off, then take out the balancer bolt, put on the balancer puller, replace the front seal if needed, lube the seal and shaft of the balancer with some oil and reverse the procedure. And in order to tighten it tight have a friend press the brake so the motor doesnt turn. :nice:
I would note that some strokers change the imbalance so going by year only is not good (not the case here since the question was about the stock balancer imbalance). Worth mentioning though.
And some aftermarket balancers require a spacer (which can be quite expensive).
Good luck.
OK if you get a rotating assembally internally balanced then can you put just what ever oz balancer on it you want as long as you match it with the fly wheel? For example if I got a rotating assembally internally balanced could I put a 50 oz balancer on it as long as I put a 50 oz fly wheel?
