  • 1994 - 1995 Specific Tech
****! Balancer?
  • Thread starter Thread starter Synned
  • Start date Start date Jun 18, 2006
1 of 2 Next Last
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Jun 18, 2006
  • Jun 18, 2006
Okay so today I decided that I wanted to try to run locked in timing to solve a different problem.
Set it everything ran great. Later today I'm going to drive home from work 1/2 way home the car starts shaking badly on acceleration. DOes it in every gear, in neutral as well.
Is my balancer spun? I tried to look at it in the dark with a flashlight, but couldnt really see. It WAS wobbling, but the rubber looked perfectly intact.
I tried to drive very slow the whole way home.
Do you guys think that its definetally my balancer? I dont think the timing can have anything to do with it.
What balancer do you guys recommend? Are they hard to change? Is there a writeup anywhere? Sorry for all the questions.
MY poor car
Thanks guys
Joe
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jun 18, 2006
  • Jun 18, 2006
If it woobled it's done...
Synned
Mar 31, 2005
991
Philly
Jun 18, 2006
  • Jun 18, 2006
I don't know if its just an illusion of the open part of the balancer against the solid part. Ill really get a good look tomorrow, from then on the car is staying parked.
HISSIN50
34
129
Jun 18, 2006
  • Jun 18, 2006
I know what you mean about the illusion.
Take a real close look at the elastomer in daylight. Look for run-out when viewed from the side.
If your timing changed again from where you locked it out and the hold down is tight, that's a sign of a spun outer ring (bad balancer).
My crude balancer thoughts: there's street ones (Pioneer, Pro Products, etc) for under 100 bucks. Then there's SFI Pioneer and a couple others for 150-200 ish. And then there's Romac for super-two-hundred beans.
I dont tach it up much, so something like a non-SFI Pioneer is something I'd get if it was the right price. OThewise, the PP unit for 80 isnt bad.
There are tons of options - I only remember the ones that would work for me.
Good luck Joe.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jun 18, 2006
  • Jun 18, 2006
Mine did just what you are talking about when it went out. Im pretty sure that is what it is. And my new one looks like its wobbling. Its an illusion. And it wont neccesarily wobble if its bad, the counterweight may have just rotated but didnt move frontwards or backwards. Mine rotated like 90*
Synned
Mar 31, 2005
991
Philly
Jun 19, 2006
  • Jun 19, 2006
I got the balancer to the point that i cant see the counterweight at all, only the front of it, and its wobbling badly.
gcomfx.com
3,690
Republic, MO
Jun 19, 2006
  • Jun 19, 2006
I put a Pioneer SFI on mine.... I like it. No heating it up to get it to fit.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jun 19, 2006
  • Jun 19, 2006
I have the non SFI Pro Products works great....
Synned
Mar 31, 2005
991
Philly
Jun 19, 2006
  • Jun 19, 2006
Heres an update guys.
The balancer looks fine visually - no spun out rubber - and I cant seem to make it move. AND the timing is the same that I set it.
However i DO see it wobbling when the engine is on. I tried runnign the engine without a belt, STILL wobbling. This takes away any other pump/pulley.
It does it in park. The only other thing i can thing of is that I'm running on 7 cylinders. I don't want to risk running a cylinder balance test while the car is running like this, or do you guys think its okay to do a quick test. Im just scared of messing the crank or crank bearing w/e it is up.
I ordered an
Professional Products 6.4 inch Damper for 5.0/5.8L (50 oz)
Guess I have to wait untill it gets here.
gcomfx.com
3,690
Republic, MO
Jun 19, 2006
#10
  • Jun 19, 2006
  • #10
If you already ordered a damper.... wait til you install that. Just to be safe. My 2 cents.
95Cobra302
394
Daytona Beach, FL
Jun 19, 2006
#11
  • Jun 19, 2006
  • #11
Just in case someone else might be looking for a balancer, you can buy a Ford Racing replacement one from 50resto for like $70 bucks. I think your getting a really good quality part for not much money. I put mine on awhile ago and really like it.
HISSIN50
34
129
Jun 19, 2006
#12
  • Jun 19, 2006
  • #12
Joe, one thing that helps me to see wobbling: I will block my view so I cant see the back of the balancer. I only look at the front edge and a reference point (in the timing cover, etc) and check run out that way. Otherwise, I cant make myself crazy (right up until I become hypnotized) trying to watch the whole balancer spin.
You have checked all your plug wires and stuff to make sure nothing popped off, right? And once it started vibrating (while driving home), it never went away and happens when you ran the car the next day?
The Green GT
1,269
Louisiana
Jun 19, 2006
#13
  • Jun 19, 2006
  • #13
Id bet money on it being the blalncer. Mine did the EXACT same thing when it went out. And I couldnt really see and bad rubber. It had just rotated.
Synned
Mar 31, 2005
991
Philly
Jun 19, 2006
#14
  • Jun 19, 2006
  • #14
Maybe, but the timing marks are right on.
I feel its the balancer too, it just doesnt feel like it could be anything else. Its a violent shake.
The Green GT
1,269
Louisiana
Jun 19, 2006
#15
  • Jun 19, 2006
  • #15
Mine actually scared me when it hit about 3000 RPM
gcomfx.com
3,690
Republic, MO
Jun 19, 2006
#16
  • Jun 19, 2006
  • #16
I had two stockers go out. The first one was easy to tell. The balancer beat the heck out of a bottom water pump bolt.
On the second stocker, it was harder to tell. On the backside I could "feel" a small section of the rubber sticking out. Not much, maybe an 1/8" or so. It was hard to see, but it's just because I caught it earlier than the first one. LOL
On the second stocker..... the key way was split when I took it off. POS.... so I went with the SFI Pioneer. Guaranteed for 10,000 rpms is good for me.
Synned
Mar 31, 2005
991
Philly
Jun 19, 2006
#17
  • Jun 19, 2006
  • #17
Yup, did that and yeah its definetally wobbling. Im just waiting for this central florida mustangs website to email me, because they wont ship it till i authorize or something.
HISSIN50
34
129
Jun 19, 2006
#18
  • Jun 19, 2006
  • #18
Sounds like a plan!
Oh, make sure the balancer spacer is included if needed.
Synned
Mar 31, 2005
991
Philly
Jun 19, 2006
#19
  • Jun 19, 2006
  • #19
HISSIN50 said:
Sounds like a plan!
How would i know if I need one?
HISSIN50
34
129
Jun 19, 2006
#20
  • Jun 19, 2006
  • #20
They should ask you - I cant remember the exact spec for a PP balancer (that's what you're getting, no?). if that's the right brand, check with their site ( www.professional-products.com ).
1 of 2 Next Last
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
