  • SN95 4.6L Mustang Tech
ball joint help please
  • Thread starter Thread starter purplestang47
  • Start date Start date Oct 13, 2009
purplestang47
55
centerville, IA
Oct 13, 2009
  • Oct 13, 2009
so my drivers side ball joint blew out on me today lucky for me i was going 5 miles an hour when it happened. i got the parts and we even got the old piece out from my a arm and got the new piece in and ready..but i can not for the life of me get the nut off the old ball and threads so i cant put the new one through the spindle to be done. i hope im explaining this well but ive trided pb blastering the s*** out of it and every position i can think of with my wrentch and vice grips can anyone please help?
2002SN95MUSTANG
Charleston, SC
Oct 13, 2009
  • Oct 13, 2009
Unless you need the nut, try using a cutoff wheel and cutting it in half. if you don't have a cutoff wheel, you could heat it up with a torch, a small propane one should work, and then hit it with a hammer and try to break it off. If you do need the nut, try shaving down 2 opposite sides of the threaded shaft the nut tightens onto into a flat surface and then use an open ended wrench to hold the shaft and try to turn the nut. Thats about all I have for ya. Hope this helps and works for ya.
purplestang47
55
centerville, IA
Oct 14, 2009
  • Oct 14, 2009
thanks i got it today after some choice words and a torch it finally came off. then i couldnt get the ball joint and threads out of the spindle.the guy at orielys gave me a ball joint puller but it was to wide i went back plenty "happy" and a more experienced guy told me a tie rod puller should work. and he was right an hour later i was done
GDawg
1,469
Nevada
Oct 14, 2009
  • Oct 14, 2009
I love threads like this cause this is the section I'm in school for right now.
M
mr-mike
122
  • Oct 15, 2009
grease those ball joints
after reading the post & for you other guys use a needle injector & push some grease into the ungreaseabble fitting every 6 months after getting some years ago I grease the ball joint & she has been good its a 99 gt I had a 90 & the ball joint let go right infront of my house had it towed & had new ball joints installed ......... bad idea when car builders went to non greasable parts
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 15, 2009
  • Oct 15, 2009
On a new edge Mustang its much easier and better to just replace the whole a-arm assembly than it is to replace the ball joint.
Check out part M-3075-D.
Ball Joints Question
  • 93gtmustang
  • Aug 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2025
AeroCoupe
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Today at 1:59 PM
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Today at 1:59 PM
Machbud
M
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
