ball joint problems help!
You don't need air tools - but I can't figure out why yours is spinning...thery aren't meant to!
I swapped out my ball joints for 94/95's. I used a ball joint press to squeeze them in and they didn't spin at all. The only time the stud spins is if something is broken inside.
Are you Sure the Entire Balljoint is not turning? Most of the time you should buy Oversized as pressing them out enlarges the hole slightly and call allow the Balljoint to spin, I have just seen guy tack weld the Balljoint to the Lower A Arm in the case of having them spin.
If you load the control arm (carefully put a jack under the LCA and jack it up a bit), it will help seat the BJ's rod into the spindle and it shouldn't turn.
Good luck.
