Ball joint ques
  • Thread starter Thread starter 310stanger
  • Start date Start date Nov 28, 2006
310stanger
170
  • Nov 28, 2006
My ball joints squeek like a stuck pig. What do you guys replace them with? Should I go factory or get those steeda versions. although something leads me to believe they arent for a fox? jus wanted some input.
Snikt89GT
264
Deland, Florida
Nov 28, 2006
  • Nov 28, 2006
If you have 94-95 spindles I would go with those FMS/Steeda X2 balljoints. If not just pick up some Moog replacements or something like that
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 29, 2006
  • Nov 29, 2006
Or you can buy Ford Racing Lower A Arms M-3075-A, they have upgraded Ball Joints and Bushings.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Nov 29, 2006
  • Nov 29, 2006
I like the one's I got at NAPA (yeah, imagine that). They're actually Dana ball joints and come with grease fittings.
EDIT: BTW, I agree with the above statement as well. I wish I could have went with new control arms when I had it apart. I was in a HURRY to fix the ball joint that I bursted with a pickle fork ..... so I had to get new ball joints instead. Getting the whole assembly is TOTALLY worth it.
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Nov 29, 2006
  • Nov 29, 2006
How hard is it to replace the ball joints? I have pickle forks for ball joints and tie rods. Is anything else needed to replace them?
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Nov 29, 2006
  • Nov 29, 2006
Ball joint removal/re-install kit.
You can rent one at the local parts stores. I rented one at O'Reilly's. Actually, I think I had to PAY for it up front ..... and got every penny back when returned. Be prepared if you got this route .... they're kinda expensive.
EDIT: you also need a BFH to go along with the fork. If you get the tool, you may not even need to use a fork. It's a PITA to do ball joints. If possible, get the control arms that already have them installed in them.
Jaswir
578
Orlando, FL
Nov 29, 2006
  • Nov 29, 2006
goto autozone and rent the press... its 100 bucks... its what i did... then bring it back in a couple hours and you get your money back!
i know harbor freight has them for like 40 bucks... if you wanted to buy your own...
really easy to do just press em out then press them back in
8950HO
658
  • Nov 29, 2006
I used Moog and they have grease fittings unlike the sealed up factory junk.
sunil6784
620
Boston, MA
Nov 29, 2006
  • Nov 29, 2006
How much are the ball joints ? I've *heard* the control arms with them already installed are not that much more money...
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 29, 2006
#10
  • Nov 29, 2006
  • #10
http://members.shaw.ca/Notchmustang/Balljoint.html
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Dec 1, 2006
#11
  • Dec 1, 2006
  • #11
For the hassle of buying new balljoints and renting a tool to press out the old ones and press in the new ones it is just much easier to get the Ford Racing A Arms and swap them into place.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
