Ball Joint Replacement with hand tools
93 LX
3,081
Norwalk, CA.
Can someone let me know if I can change the ball joint wiht common hand tools?
I would like not to remove the control arm if it is possible. I have removed spindles, struts and the like but never had to change a ball joint. Can anyone help?
Allen
BTW this is on my 93 LX
I'm almost certain that the ball joints are a press fit, so the control arm needs to come off to replace them. Can't help on what tools you'll need exactly, but you'll really want an impact to get the control arm bolts loose, and probably a ton of penetrating oil.
You can loan out a BJ removal/install tool from the parts store. It works well enough that I purchased one (not from the parts store) because they also work well on U-joints.
ANyhow, here'd be my approach. Assume you will need to take the FLCA off the car (the oh crap scenario). That way you're ready. It's not that tough to do if you have a couple decent floor jacks.
Now if things go well, you wont need to do that. You can use the BJ tool on the LCA with it on the vehicle. It helps to have an air gun available, but I've done them with an 18" breaker bar.
Anyhow, that's my approach to things on these old cars (plan on the LCA not being nice and needing to be removed, and then just see how it goes).
As I'm sure you know, you can get new loaded control arms. They're $$ these days but still are a decent deal if your old ball joints and bushings are all shot.
Good luck.
