Ball Joint ??
  • Thread starter Thread starter KENS89LX
  • Start date Start date Jun 3, 2015
KENS89LX
302
Cross lanes Wv
Jun 3, 2015
  • Jun 3, 2015
I am replacing my ball joints tomorrow, and need to know if a 95 v-6 is the same as a v-8. I also need to know if they would fit in a 89 lower control arm. I switched it over to five lug years ago from a 95 v6.
MFE92
1,094
373
124
Phoenix
Jun 3, 2015
  • Jun 3, 2015
Yes and yes, but ditch the spacer you used on the foxbody balljoints when you installed the SN95 spindles.
Reactions: squeak93
KENS89LX
302
Cross lanes Wv
Jun 3, 2015
  • Jun 3, 2015
alright, thanks
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Jun 4, 2015
  • Jun 4, 2015
In addition, you will need a new nut for the ball joint. A Fox ball joint and a SN95 ball joint use two different nuts.
I am basing this off of the fact that I bought a set of MM control arms with SN95 ball joints already installed and it required a different nut size. You may need to research a little more yourself.
Joe
squeak93
2,312
391
164
Joplin, Missouri
Jun 4, 2015
  • Jun 4, 2015
Have fun with the ball joint press if doing it by hand..... It will kick your tail end.
That being said, if buying the ball joints new, they should come with the nut and even a new cotter pin to install. (don't forget to grease them once installed.)
RangerJoe
2,560
1,146
184
Georgia
Jun 4, 2015
  • Jun 4, 2015
Yep, I just checked Autozone website, they do come with new nuts and pins.
Joe
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jun 4, 2015
  • Jun 4, 2015
Stick with Moog replacement ball joints. Get the 94/95 ones, they press right in and come with everything.
KENS89LX
302
Cross lanes Wv
Jun 4, 2015
  • Jun 4, 2015
Well, hot that one done, had to cut the old joint at about where the threads started to get the press to work, with the adapters I had to use. Now for a al I alignment, seems to wonder all over the road thought maybe the new ball joint would help but it didnt..
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jun 4, 2015
  • Jun 4, 2015
Have you checked the inner and outer tie rods because if they are bad they will make your car handle real bad and will cause the car to wonder. I just replaced mine last month..i did the inner and outer and they are very easy to replace .. all you need is a large pipe wrench.
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,946
5,818
213
Jun 4, 2015
#10
  • Jun 4, 2015
  • #10
Don't forget to check the rag joint on the steering column. That little rubber disk can cause bad wandering if its worn out.
KENS89LX
302
Cross lanes Wv
Jun 15, 2015
#11
  • Jun 15, 2015
  • #11
Ok thanks, I have the steeda bumpsteer kit on it, the rag joint is right by the headers?
90sickfox
Mar 2, 2015
6,946
5,818
213
Jun 15, 2015
#12
  • Jun 15, 2015
  • #12
Yup...that rubber disc in between the steering column by the headers.
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
Ball Joints Question
  • 93gtmustang
  • Aug 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2025
AeroCoupe
T
Resolved Steering won't return to centre
  • Tom77
  • Apr 28, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
Tom77
T
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
