Ballast Resistor
66mustangg
59
Westchester, NY
Im in the middle of doing all my wirirng over and my kit came with a ballast resistor. I was wondering if i should intall it beacsue the directions give options on wheather to install it or not. and if i should, where should i mount it?
thanks
resister
thanks
There is a resister wire between the ignition switch and the coil. If you replaced that wire, you need to put the resister in.
