Fox Bama 4-bank Eliminator Chip - Worth Buying?
cdurbin
5 Year Member
Jul 27, 2012
563
109
64
North Charleston, SC
I'm considering buying a Bama 4-Bank Eliminator Chip from americanmuscle.com for my 91 LX Vert.
I wanted to get your opinion/experiences with the product. My engine is not highly modified at all. Basic mods like cold air kit, electric fan, alternator upgrade, headers. Would I really see any worth while gains from this investment? I would really like to see improved idle and throttle response. Seems easy for a novice to install and the online reviews are descent. I trust your opinions more than most. Thanks
not really
You should wire up the fan to the ecu and let the ecu turn it on and off
You shouldnt have any idle or throttle response issues
Clean out the throttle body, remove the mesh screen under the pcv valve in the back of the manifold and do a base idle reset
if you set timing to 14 degrees you wont notice anything from the chip
not really
Yeah, I've cleaned the throttle body, IAC, MAF. I bought a new PCV and screen but I can't see where the hell the old one is to change it...lol I'm short. The timing is set at 10 degrees right now
not really
I wouldn't say I have an idling problem. It idles really well for the most part. There is a slight drop in it from time to time. That may be normal though and I wouldn't know because this is my first Fox
