  • 1994 - 1995 Specific Tech
Banging Swaybar
  • Thread starter Thread starter Synned
  • Start date Start date Sep 5, 2007
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Sep 5, 2007
  • Sep 5, 2007
Last night I got so sick of this banging...I still haven't had time to get it in the air but last night I put my arm under the rear and yanked on the swaybar, SUPRISE, moved about an inch backwards towards me. Its got an inch of play back and forth.
This isnt supposed to happen, right? lol. Does this usually mean bushings or just a bolt needs tightening?
EDIT: just realized that its not the swaybar...I don't know what its called the suspension bar in the rear by the gas tank that goes across horizontally. Swaybar?
94-302-vert
1,947
NE CT
Sep 5, 2007
  • Sep 5, 2007
Yep, that is the sway bar. Not supposed to have any movement at all. Take it off. there are 2 bolts per side on the lower control arm. I think they are 15mm and you may be able to do it without removing the wheels if you feel so inclined.
Synned
Mar 31, 2005
991
Philly
Sep 5, 2007
  • Sep 5, 2007
Well, I would like to fix it instead of just taking it off, due to the fact that the front swaybar is already removed.
94-302-vert
1,947
NE CT
Sep 5, 2007
  • Sep 5, 2007
I actually think that running only a rear swaybar is hurting more than helping you here. I think it will contribute to oversteering.
I would remove the rear and replace the front if at all possible.
Now as for fixing it (since that is the actual question) you have to see why it is loose. It could be unbolted or it could be broken. Either are highly probable. Best bet is to get under there and see what is going on (back it onto some ramps maybe?).
go-stang5.0
2,244
Glenview,Il
Sep 5, 2007
  • Sep 5, 2007
yea either the swaybar is broken or the bolts are broken or backed out. There are no bushings/endlinks on the rear swaybar...they just mount directly to the control arms. If you need a bar I'll sell you mine..its in good shape. $50+ shipping.
Synned
Mar 31, 2005
991
Philly
Sep 5, 2007
  • Sep 5, 2007
Its broke. Snapped right off by the rear passenger bolts.
Ah well, at least I found the problem...
donkey_punch
565
northern****ingjersey
Sep 5, 2007
  • Sep 5, 2007
time to upgrade
Pokageek
2,767
MA, USA
Sep 6, 2007
  • Sep 6, 2007
What would one upgrade to for a rear sway bar? Do they make larger ones per say?
go-stang5.0
2,244
Glenview,Il
Sep 6, 2007
  • Sep 6, 2007
EVm adjustable, MM adjustable, eibach, addco, and just about any fox swaybar. Different years had different stiffnesses between the cobras and gt's, lx's etc. If you can find a list of which ones are stiffer/softer then you can decide what you want. I personaly like a little softer than stock Gt bar. but thats just me.
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
L
Torsen T2R (M-4204-T31H), excessive play?
  • letumeternum
  • Aug 24, 2023
SN95 4.6L Mustang Tech Aug 24, 2023
letumeternum
L
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
M
  • mnky99
  • Sep 5, 2025
mnky99
M
