Alright, as a long time member of the board I have searched this topic over and over and really never got extremly cut answers... plus this has a little twist so Im gonna go ahead and ask.
To start, Im currently building a mexican 331 stroker for the stang. So, since the engine I currently have is basically getting the boot and I will have an empty engine bay during the swap I've been kicking around the idea of deleting the smog pump while im at it for the weight savings and even more sore for athestetics.
A) I've heard of potential proplems with the smog pump removal dealing with a/f ratios because the o2's arent getting a correct reading... this true or am I off here???
B) I live in Indiana (no emmision testing) so of course I have an O/R h-pipe (no cats)... is there anything else the removale of the smog pump is going to effect badly?
C) or what I like to call.. the *twist* The stang currently has an SC-Trim Vortech blower and will be switched over the new powerplant when the time comes. (prolly getting the trade in upgrade to S-trim since I can afford it and will probably need it) Anyways, the blower required moving a lot of the accessories around using its own bracket. This has got me thinking. Is it still possible to run the smog pump delete kit pulley with the vortech bracket? Is it still possible to run the belt without a smog pump pulley and not interfer with anything since the other accessories are moved and not exactly like a stock setup???
Im sure answering #C is gonna be tough, but I would like some answers if anyone has got them.
Thank you.
Thank you.
