Bass Blues
  • Thread starter Thread starter 68conv4sp
  • Start date Start date Aug 8, 2006
68conv4sp
270
  • Aug 8, 2006
How do you guys get good sound sytem bass into your cars? I have a 12" in a ported encloser in the trunk powered by a 250 rms amp. But with the top down, the sound has to pass thru the folded window, conv top, and rear seat. Not much left after that.
iskwezm
4,159
20
79
Rowland Heights,California
Aug 8, 2006
  • Aug 8, 2006
I just made a box for my 06 vert and ported the box into the interior.
The top shouldnt block all your bass. My buddy, we did 2 10"s in his 65 vert and it sounded pretty good.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 8, 2006
  • Aug 8, 2006
I got all the bass I need from my 2 magna flows =)
68conv4sp
270
  • Aug 8, 2006
OK, so if I can synchronize the exhaust pulses thru the glass packs, it should be all the base I'll ever need.
Seriously:
iskwezm, I may not be using the right terminology, but did you just connect the bass enclosure port to the interior of the car without having to cut 12 inch holes in the trunk panel?
M
mustangman70
1,235
St pete, Florida
Aug 8, 2006
  • Aug 8, 2006
What kind of amp do ya got running them
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 8, 2006
  • Aug 8, 2006
A 5.0 baby =-)
On a more related note to the thread:
I think a sealed sub box will produce a much better sound than a ported box can. A good pair of 10" woofers in a sealed box will sound fantastic. A ported box does not produce the same sound as a sealed box does. I always recomend going with a sealed box.
M
mustangman70
1,235
St pete, Florida
Aug 8, 2006
  • Aug 8, 2006
Dont forget that subs are created for specific boxes alot of times for the best output
J
jamison42166
112
  • Aug 8, 2006
I second the sealed enclosure... im running the enlosure with 2 ten inch kicker subs and a 100x2 kicker amp. i mounted the amp to the enclosure and ran all the wiring through the enclosure itself with a plug on the back so i can take the enclousre out completely if i want.
M
mtbdoc
245
  • Aug 9, 2006
Okay, I will admit it: I am a psycho! Besides that, I like fast [okay, scary fast] cars and clean, loud music [okay, I want the ability to remove anyone from the car with the stereo...no James Bond ejection seat required].
Solution: if you look at the linked thread on my 'vert, we built dual roll bars behind each seat [come on, Iacocca wanted this car to be a 2 seater...]. Nestled inside of each roll bar will be an Elemental Design 16Ov.2:
They will be wired w/ each 4 ohm vc in parallel, and each speaker in parallel, presenting 1 ohm to the Elemental Design 9.1 producing 1200w @ 12v:
Look...I turn 50 next year. If you're going to have a mid-life crisis, have it in a totally insane 40+ yr old Mustang 'vert w/ 800+ hp and too much stereo.
Questions?
Seriously, getting adequate bass in a convertible is always hard as you lose cabin "near field" reinforcement. Even your house is better. Basically, this system will have to supply bass to the entire world, w/ the response dropping exponentially as you get away from the driver. In my case, this car should play loud and clean...20+ feet away.
Shakin66
628
Waycross, Ga / Lake James, NC
Aug 9, 2006
#10
  • Aug 9, 2006
  • #10
Yea, a convertable is going to be tough. I have 2-12" mounted behind the rear seat powered by an old school fockford fosgate punch 150 and they are plenty loud but your going to have a hard time doing anything except maybe a box in the trunk I'm afraid.
68conv4sp
270
#11
  • Aug 10, 2006
  • #11
mtbdoc, I turned 40 this year and continue feel the need for higher HP and dB. However, this is not a mid-life crisis as I always wanted the above, just have more $ now.
Shakin 66, what about putting bass drivers under the front seats? Is there room for the shallowest units? That would be true Seat of the Pants driving.
Shakin66
628
Aug 10, 2006
#12
  • Aug 10, 2006
  • #12
I have aftermarket seats that are bolted flat on the floor so I am not sure on stock seats, Maybe. I just like to REALLY hear my music and the 12's do a great job of that. Not BOOM BOOM mind you but good deep bass, heck I have 4 tweeters in the dash area. But I am a true music lover and have been known to sit in the car to listen to new Cd's as it sounds much better that my home system.
iskwezm
4,159
20
79
Aug 10, 2006
#13
  • Aug 10, 2006
  • #13
Seriously:
I ran 2 3" port tubes to the side where the top folds down. The box had too many angles, so the bass started to break it apart. Now im going to 'glass the 2 Orion 12's into the spare tire well.
The reason people use a sealed box is because theres no guess work in making them. In a ported box,theres more room for error and they can sound horrible with the wrong port.
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
For Sale 2000 GT Convertible 4.6 5 SP Exterior/Interior parts remaining from donor car
  • Tods Hot Rods
  • Sep 17, 2024
  • Suspension Parts
Suspension Parts Sep 17, 2024
Tods Hot Rods
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
