Batt relocation question
  • Thread starter Thread starter mcclelland21
  • Start date Start date Dec 21, 2007
M
mcclelland21
15
San Diego
Dec 21, 2007
  • Dec 21, 2007
looking to relocate my batt to the trunk. have searched several posts on this matter but still have the one question. Battery box is easy to install and ground wire is no problem but...
What is the best way to route the positive cable from the trunk to the engine bay? any pics would help! Thanks!
D
D.Hearne
11,730
south louisiana
Dec 21, 2007
  • Dec 21, 2007
Run it along the inside of rocker panel. At either end, route it where it's out of the way and best protected from damage.
xoxbxfx
3,959
Southlake, TX
Dec 21, 2007
  • Dec 21, 2007
I routed mine over the wheel well, through the trunk to the spot where the 1/4 window sits, through the rocker panel (under the sill plate) and then drilled a hole in the floor and routed it to the engine bay. Basically it follows the same path of the tail harness but on the passenger side.
rbohm
6,698
550
204
tucson,az
Dec 21, 2007
  • Dec 21, 2007
when i do mine, i will run the power cable through some flexible electrical conduit, and run it along the outside of my subframe connectors.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 21, 2007
  • Dec 21, 2007
When I put subframes in mine I'm going to trunk my battery. I was going to run the cable in side my subframe connectors.
I
iapexl8r
254
Dec 21, 2007
  • Dec 21, 2007
be sure to add a ground wire from the engine to the chassis. chris
M
mcclelland21
15
San Diego
Dec 22, 2007
  • Dec 22, 2007
thanks for the help!! I ran it over the wheel well and through the rocker panel.
D
D.Hearne
11,730
south louisiana
Dec 22, 2007
  • Dec 22, 2007
With a unibody like a Mustang (old unibody at that), it's not a bad idea to run a separate ground cable along with the positive cable. It might save you some headaches later on.
Engine Crankcase vent tube “relocation”?
  • Mcmahst
  • Nov 20, 2025
Fox 5.0 Mustang Tech Dec 20, 2025
manicmechanic007
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Fox Jump/start - Charging
  • PonyGTrider
  • Oct 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
PonyGTrider
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
