Mine's on the passenger-side in the trunk. I'm not entirely sure it'd pass NHRA tech at the track, since I don't have an exterior cutoff switch, but otherwise, whoever did it did a pretty decent install. They bolted a metal plate base inside of a plastic marine battery box that allows the use of a pair of J-hooks with the top H-bar, and ran welding cable (can't remember the gauge off hand ... either 1 or 2, not sure) up to the starter solenoid up front. The original ground they had was lame - just used one of the bolts for the tail light housing to ground it to the body, sheesh - so I made a new solid metal-to-metal bolt to the frame by the shock tower and a second 4-gauge ground cable running to the quad shock mount.
It barely cranked over when I first bought it, but since beefing up the grounds, it has no charging problems (aside from the inherent issues with running a stock alt. with an electric rad. fan) and it starts like a champ ... well, at least it will when I replace the ValueCRAP starter in there with a bling-bling purty brand-new Duralast Gold unit, tomorrow morning.
As far as left or right location, I only found mine being on the passenger-side to be a PITA when I was fiddling with removing the fuel tank fill spout to put on a new tank grommet and a piece of side molding, but it makes for a nice, discreet hidey-hole that I store my spare clutch cable, jumper cables, and a few other odds n' ends in. It's also on the same side as my Eibach Drag Spring airbag, and even in a limited-slip rear car, the right tends to be what more folks worry about focusing their traction (due to rotational forces and torque or something, I suppose).
Oh yeah, and don't route your cable through the interior, obviously. Electrical fires are bad, especially in the passenger area. Ditto for running the cable along the passenger's side, parallel to the fuel lines. Something about a random fuel leak and a bad ground, followed by a burst of flame and/or explosion ... I dunno...
