  • 1994 - 1995 Specific Tech
Battery cable replacement..question ?
  • Thread starter Thread starter Pokageek
  • Start date Start date Aug 18, 2007
Pokageek
2,767
MA, USA
Aug 18, 2007
  • Aug 18, 2007
Hi guys,
I am replacing my battery cables. Just checking to be sure i didnt miss nuthin..
Positive batt cable goes to that box on the dr side..then another cable goes from there directly to starter...it's that simple right? do those cables branch off or is it that simple?
The neg cable I'll have to trace..i know a ground comes off it to the radiator support like Grady said but then I have to see where it goes...any help from y'all experienced flks? thx.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Aug 18, 2007
  • Aug 18, 2007
The positive is correct. The negative runs into the harness with the O2 sensor wiring, so it's a little more of a PITA to replace because you have to open up the harness to replace it. It runs from the battery to the timing cover, just above the oil pressure sending unit.
Pokageek
2,767
MA, USA
Aug 18, 2007
  • Aug 18, 2007
ugh. ok. thanks. hmm.. for now I could leave the neg in the harness and just disconnect to get the car running!
BlownFiveLiter
18
108
Chicagoland
Aug 19, 2007
  • Aug 19, 2007
You could just abandon the negative in place, cut off the ends where it goes into the harness, and run new cable. I did it by opening up the harness only because I had full access to it with my engine out.
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
R
Electrical Trunk Mount Battery and Cut Off Switch- Need Help
  • Rcdgl
  • Nov 20, 2024
Fox 5.0 Mustang Tech Nov 20, 2024
nickyb
Questions Replacing Cam Synchronizer
  • Blackout67
  • Jul 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 23, 2025
01cstang
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
