  • 2005 - 2009 Specific Tech
Battery Dies after 4 days of being parked
  • Thread starter Thread starter hammerhead399
  • Start date Start date Nov 26, 2010
H
hammerhead399
  • Nov 26, 2010
I've got a 2005 GT, 5-speed w/ 39k miles on it. Had it since 12-2004 and in the last 6 months the battery goes dead after sitting parked for 4 days. I bought a new Optima red top thinking it was the battery but same problem. Alt volts are between 13.5 and 14.5 when running, have a scan gauge in the car. Has the factory alarm and shaker 500. Batt goes dead whether alarm is on or not. Its not the trunk light staying on, checked that. Had the water problem in the pass floor from the leaking window trim and the temp gauge went out. Anyone having the same problem? Suggestions? Is the alt voltage too low? Warranty is expired obviously.
ski
380
Nov 27, 2010
  • Nov 27, 2010
Recharge the battery with a trickle charger.
Then, always make sure to manually turn off the radio(switch it to AM/FM mode if it's in CD mode before turning it off) before turning off the engine.
If the battery still goes dead, then the radio unit may need to be either repaired or replaced.
R
Rei_h
  • Nov 29, 2010
Is the thing about the radio a common problem? Please let me know if there's a thread about it. I recently bought a used 2006 GT and noticed that the radio never turns off on its own when I turn off the engine, but I thought it was going to turn off after a while, so I didn't do anything about it the first day. But knowing that the battery was dead when I bought it, I was really cautious about electric units in the car, so I've always been turning it off manually before turning off the engine. Supposed if I don't do that, is it going to stay on until the battery dies??
I'm starting to hate this car. It already has that other problem about the gas tank (I have to turn the nozzle upside down to fill up the tank at some stations), and I'm discovering another annoying problem which I'm going to post here soon... I miss how my '99 GT was driving after 10 years and over 107K miles on it.. It never had any of these annoying problems..
ski
380
Nov 29, 2010
  • Nov 29, 2010
There are dozens of threads regarding the radio problem on all of the Mustang forums.
Your 99 may have been more trouble free, but your 06 is light years ahead of it in performance, handling, comfort, style, etc.
R
Rei_h
  • Nov 29, 2010
yes, that's true. sorry... just that i hadn't bought a newer car in 10 years and wanted it to be trouble-free, but oh well.. thanks though. i'm looking it up.
ski
380
Nov 30, 2010
  • Nov 30, 2010
You're welcome.
streethorse
1,042
Dallas Texas
Nov 30, 2010
  • Nov 30, 2010
The radio should turn off as soon as you open the door, mine does.
As for the gas problem, try a different gas station and fill up on the
slowest setting.
ski
380
Dec 2, 2010
  • Dec 2, 2010
Sometimes the radio stays on, or can even turn back on, after shutting the door.
WTTW-Always turn it off manually.
M
mustang128
  • Jan 23, 2011
06 mustang battery goes dead dealer no help i always turn radio off first. NOW I AM BUYING A BATTERY TENTER AT WALLY WORLD
W
Wayne K
61
#10
  • Jan 25, 2011
  • #10
Check for excessive draw on your battery with a multimeter set for checking amps. Pull one fuse at a time until you find the circuit that has excessive draw. Then eliminate each item in the circuit.
J
joshgotamustang
Houston, TX
Jan 28, 2011
#11
  • Jan 28, 2011
  • #11
best solution is to just go for a joy ride everyday
RMB427R
Finleyville, PA
Feb 12, 2011
#12
  • Feb 12, 2011
  • #12
+1 on the battery tender idea. I put them on all my stored cars and never have to worry about the battery. Also, I'd bet that the radio issue is the culprit..
Good luck!
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
