battery dies when a/c is on
  • Thread starter Thread starter stykthyn
  • Start date Start date Jun 15, 2007
stykthyn
5,232
2,652
223
gainesville
Jun 15, 2007
  • Jun 15, 2007
when I run my a/c while I am driving I can literally watch my voltage drop. does this sound like a bad alt?
cjones
1,561
Avondale, AZ
Jun 15, 2007
  • Jun 15, 2007
do you have underdrive pulleys on??
what is the voltage?? 13.5 - 14.5??
have the alt and charging system checked at a good parts store. most can check it on the car.
HISSIN50
34
129
Jun 15, 2007
  • Jun 15, 2007
Also tell us if the voltage drops that much from having the AC simply on, or if it's from having the AC on AND having the HVAC fan running on high or one level below high. Also, how does it do while RPM's are higher than idle?
It is possible you dropped a diode - high load charging takes a fat doo-doo when this occurs. The parts store test will show that (even the dynamic test they do curbside at your car can often detect this).
Good luck.
stykthyn
5,232
2,652
223
gainesville
Jun 15, 2007
  • Jun 15, 2007
It drops while I am moving. I can understand if it was at idle as I still have the stock alt, but when I am doing 65, it should be cranking out more than enough current. the needle is usually at he 1/2 mark or a tad higher, but when the a/c clutch kicks on it plummets like a rock. My stereo cuts out and my guages freak. This happens regardless of rpm, so that is why I am leaning towards a bad alt.
93 LX
3,081
Norwalk, CA.
Jun 15, 2007
  • Jun 15, 2007
sounds like you have a bad short in the clutch circuit or a bad clutch itself. Remember the clutch is a magnet which ic a coil of wire. If the coils are shorted together it will draw a ton of current thus killing your charging system.
Allen
stykthyn
5,232
2,652
223
gainesville
Jun 16, 2007
  • Jun 16, 2007
alrighty guys I just completed the 6g alt swap and this thing runs like a champ. no more drainage issues at the moment.tomorrow we'll see if they stay gone. thanks for all of the input.
G
2000 GT- Alternator not charging
  • grugug
  • Nov 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 12, 2026
squeak93
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
martroy
M
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
