I did some test and came up with this . I unhooked the negative battery terminal and hook a test light to the battery and touched the core support , it lights up so this tells me I have a drain. I start pulling wires off the hot side of the starter relay , the lght goes out when I pull the yellow wire that turns into 4 wires . I hook this wire straight to the battery and light comes on ,as I get into the car to start looking the open door chime starts dinging . While it is dinging ( battery ground wire still unhooked ) the test light flashes the exact same time it dings every time . I unplug the plug at the steering column the light goes out a little more but the door chime is still dinging it keeps going until I take the key out of ignition. What the hell is going on ??
