Battery Draw Test Procedure
  • Thread starter Thread starter ninety15.0
  • Start date Start date Nov 22, 2007
ninety15.0
1,336
  • Nov 22, 2007
Hey guys...i've had this problem lately with my battery going dead after just one week of the car sitting. I just went out there to start the car now and it was completely dead. The car has a 130A 3G alternator on there with all the appropriate wiring...and the car charges fine when running with no accesories on. When in turn the lights on however, i can see a noticeable draw in the bat voltage.
I was wondering if anyone has a good parasitic draw test procedure for identifying circuits that may have problems. I was thinking to just use a DMM to test the voltage at the battery posts. I'm expecting to see something less than 12V obviously. Then i was thinking to start pulling fuses until voltage draw stops. Does anyone have any other ideas or procedures for tracking down problems? Thanks in advance!
jake2582
107
tallapoosa
Nov 22, 2007
  • Nov 22, 2007
what you want to do is test it on amperage
make sure nothing is on and disconnect the neg bat cable.
connect one lead of the meter to the bat. cable and one lead to the bat. post
meter should be set to measure amperage and it should not pull more then like .2 amps. (clock, radio and pcm memory) should be all in use.
if it is more than that pull fuses till you find it.
BTW: if it pulls more than 10 amps it will blow the fuse in your meter.
BTW: battary voltage should be 12.65V when the car is just sitting and 9.86V with the starter engaged for 10 seconds.
ninety15.0
1,336
  • Nov 22, 2007
Jake...thank you for the information. That was very helpful. So instead of testing the voltage across the bat, i should be testing the amp draw through the circuit. Do you know if the headlight and taillight circuits are on the same fuse? or if they are even fused at all? Thanks again for the help!
jake2582
107
tallapoosa
Nov 22, 2007
  • Nov 22, 2007
i dont know that.
but be sure not to turn anything on or else you will blow the fuse in your meter. like i said it is usually only 10A fuse.
HISSIN50
34
129
Nov 22, 2007
  • Nov 22, 2007
Yes, the headlights and taillights are fused. You will be looking for an item staying on, so chances are that the headlights and tails are not the issue.
Be very sure all glovebox lights, vanity mirror lights, trunk lights, etc are all turning off. Those guys will wipe your battery's butt if left on for a couple nights.
I do the same method of testing (current draw with an ammeter in series with the disconnected negative battery cable and terminal). Remember to re-peg your DMM (most require moving the Positive lead to the third port).
You can check specific gravity with a hydrometer. Or each battery cell should have just over 2.1 volts.
Good luck.
ninety15.0
1,336
  • Nov 22, 2007
no its not anything simple like a light staying on...i have checked all those possibilities many times. I think this is probably an exposed/grounded wire that isnt supposed to be. I have been doing some reading about how to test for parasitic draw...i will try it tomorrow and see what i come up with. thanks again for the help guys...
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
J
1990 fox starts on starting fluid only
  • Jfox
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
AeroCoupe
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
