For those of you with your battery in your trunk, where did you pick up a good ground for your negative battery cable?
Tim
Tim
Not true, every spot weld is another pathway....there is no better ground conduit than a unibody, 40 years old or not.D.Hearne said:Just me, but on a unibody style car such as a Mustang, I'd run a separate ground cable back up to the motor, this will give a better ground than a 30 something year old unibody.
Ronstang said:Not true, every spot weld is another pathway....there is no better ground conduit than a unibody, 40 years old or not.
I'd still run a ground cable. 30 year old Unibody or not, Copper is a better conductor than steel. D.Hearne said:![]()
For stereos I agree......HAHAHAHAHA.....but I don't like cables under the car to begin with so one is more than enough for me. I built an 93 EFI street/race car with a battery in the trunk. I grounded the battery to the frame and then ran a 10ga copper ground cable directly to the EEC IV as I felt this was a safe way to do it....but engine is grounded to the frame in the front and uses the unibody as the conduit for the starter and it has never been a problem. But as usual eveyone must do what they feel is right. vobraman said:can someone post some pic's of the battery mounted in the trunk ?
thanks
