I've a 1992 Mustang LX 5.0, and my Mom's fiance replaced a battery in it before I purchased it, since then the battery has had a slow drain to it, I took the battery down to Schuck's and had it tested, one of the cells was dead so they replaced it for free. I put in the new battery and it still has a slow drain that will completely discharge the battery in 1-2 days. I just replaced the battery cables hoping that would be the problem but it still looks as if there is a power drain. Has anyone else had a problem like this or any idea as to what could be causeing the slow leak?
Another question is, does anyone else have the clunking noise in their gas tank? Whever I roll over a speed bump there's a lot of it going on, I thought it was stuff in the trunk shifting around, but took it all out and went over some more bumps. My Fiance and I ruled that it must be the gas pump, Ford does put the pumps in the gas tank right? Should it be making all this noise or did something come loose?
