Battery Relocation Fail - HELP
Anti_Hero0932
5 Year Member
Jan 29, 2012
432
187
63
29
LaGrange, MO
I need some help guys idk what’s going on with my car but I think I have a ground problem. Where did everyone ground their battery’s and blocks when you move your battery to the back hatch.
Also on the drivers side fender well there is a group of wires that are all black with a green tracer. All grounds. I would guess.
There is a black with a red tracer in that same bundle of wires. Is this supposed to go to the starter solenoid? I have noticed sometimes if I’m under the car working on it I will get a bolt of static electricity as well.
All in all I can’t get some of my digital gauges to work right so I’m trying to find out my problem I guess this is where I need to start.
Help help help
  • Sponsors(?)
Anti_Hero0932
5 Year Member
Jan 29, 2012
432
187
63
29
LaGrange, MO
As far as I can tell yes. I did a wire tuck but I labeled everything. The only thing I can think of is the battery to body ground isn’t good enough so I’m gonna try to re do that tomorrow.
My AFR on my MS is reading almost exactly 1 AFR higher than the gauge. The gauge is correct and I have all the setting correct I’ve double and triple checked them even called the guy who sells them and he’s saying it’s all right and he thinks it’s a bad ground some where. I’ve seperated the 02 Heater ground from the controller ground as well. I’m getting to the breaking point with this thing
Anti_Hero0932
5 Year Member
Jan 29, 2012
432
187
63
29
LaGrange, MO
Yes sir comes out of the bottom of the hatch and is bolted to the frame by the upper control arm on the rear end. The at the front of the engine there’s a bolt I connected to and it goes over to the front frame horn. I’m wondering now if the bolt goes to the timing cover or the block now.
Anti_Hero0932
5 Year Member
Jan 29, 2012
432
187
63
29
LaGrange, MO
I think it’s 1/0 or bigger it’s the same size we use at work for 4000 LB cranes. It does crank over pretty good.
Like I said it’s really odd when I did my fuel pump I got shocked every time I touched the gas tank. Every once in a while I will get shocked when I get out of the car. But the battery never goes dead and it starts and charges just fine
General karthief
Mod Dude
Aug 25, 2016
16,814
5,365
193
polk county florida
The shocks your getting is likely static electricity, nothing to do with the battery.
Sounds like you have a body harness ground problem. You did connect the fender ground that went between the battery original place and the starter solenoid and the ground from the drivers side block to the firewall.
Anti_Hero0932
5 Year Member
Jan 29, 2012
432
187
63
29
LaGrange, MO
The one on the back of the head that goes to the firewall is connected. The one on then battery your talking about is the black with green tracer I’m pretty sure. I cut the end off and put a ring terminal on it and grounded it to the under fender well. Cleaned the pint off before it bolted it to the fender well.
Anti_Hero0932
5 Year Member
Jan 29, 2012
432
187
63
29
LaGrange, MO
Also I think the black with red tracer going up to the solenoid is a power for the ecu and the relay in the kick panel acording to what I’m reading so that should be right
Anti_Hero0932
5 Year Member
Jan 29, 2012
432
187
63
29
LaGrange, MO
well... i guess im going to check my ground strap at the back of the head mayb change the location of where it bolts to. and then run a ground wire from the back of the car to the front where my engine harness grounds are and see if that works... idk what else to do.
General karthief
Mod Dude
Aug 25, 2016
16,814
5,365
193
polk county florida
Don't need to move that drivers side ground, if it cranks strong then the battery grounds are ok, we need to investigate the possibility of a bad harness ground.
Anti_Hero0932
5 Year Member
Jan 29, 2012
432
187
63
29
LaGrange, MO
do you have any kind of diagram of what colors the grounds are? like i said theres a big bundle of black and green wires i have grounded to the frame rail. ive look through the harness again and dont see any other ones.
the other thing im wondering is if i have a wire thats supposed to go to the solenoid, grounded (lol)
Anti_Hero0932
5 Year Member
Jan 29, 2012
432
187
63
29
LaGrange, MO
i did check the location of the ground at the front of the engine from the block to the frame and is the correct location from what im reading on the inter webs.
i would agree with you on the engine harness i just need some way of checking them with colors or something i guess.
Thread starter Similar threads Forum Replies Date
D Battery relocation subwoofer concern SN95 4.6L Mustang Tech 1
S Where does this negative cable go??? 2005 - 2009 Specific Tech 3
J Help! Battery Relocation Cable/fuse Size Issues?!?! Fox 5.0 Mustang Tech 19
A Electrical Battery Relocation Problems 1994 - 1995 Specific Tech 3
bird_dog0347 Battery Relocation Kits, Talk To Me Goose... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 45
Knowbody Fox Battery Relocation 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
screamin gt Trunk Battery Relocation Thoughts SN95 4.6L Mustang Tech 8
pete_05_gt Upr Battery Relocation Help Fox 5.0 Mustang Tech 7
M Battery Relocation 1994 - 1995 Specific Tech 1
9 Wire Tuck And Battery Relocation The Welcome Wagon 4
B Electrical Need Help Relocating Battery On 94 Cobra Fox 5.0 Mustang Tech 2
R Battery Relocation 1965 - 1973 Classic Mustangs -General/Talk- 10
Fordfreak93 Battery Relocation Ground Opinion 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
MustangMando Battery Relocation For Efi 1965 - 1973 Classic Mustangs -General/Talk- 4
sen2two Relocating My Battery.... Solenoid Just Clicking? Fox 5.0 Mustang Tech 14
billison New battery tray vs trunk relocation Fox 5.0 Mustang Tech 23
JymboSlice Anyone with a battery relocate? SN95 4.6L Mustang Tech 8
rio95 battery relocation question and opinions needed 1994 - 1995 Specific Tech 21
moonraker Battery relocation - what fuse? Classic Mustang Specific Tech 5
S Steeda battery relocation kit Drivetrain Parts 1
87WhiteStang1 just did battery relocate Fox 5.0 Mustang Tech 3
D Battery Relocation, what a pain 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
70vert 31" radiators thread - battery relocation mandatory. Classic Mustang Specific Tech 10
RickieFrat Mustang Battery Relocation Kit Interior Exterior Parts 0
Rickyll7 battery relocation kit... 1996 - 2004 SN95 Mustang -General/Talk- 7
1 3G alternator, Mini Starter, and Battery Relocation Classic Mustang Specific Tech 8
Adam95GT Battery Relocation???? 1994 - 1995 Specific Tech 6
K Help relocating battery Fox 5.0 Mustang Tech 7
Sanctus Battery Relocation ? 2005 - 2009 Specific Tech 9
mhanksii NHRA Rules and Battery Relocation 2005 - 2009 Specific Tech 7
Brother Battery Relocation Regional Forums and Event Information 2
GTA_V6_Mustang Just got battery relocation kit... Anything I should know? 1994 - 1995 Specific Tech 1
98blackstallion battery reloc. kit, rear drag springs?? SN95 4.6L Mustang Tech 20
StreetDreamsGT Should the power and ground wire both be the same size for battery relocation? Fox 5.0 Mustang Tech 7
what9612 anyone with a battery relocation kit? 1996 - 2004 SN95 Mustang -General/Talk- 9
Guero Battery Relocation Fox 5.0 Mustang Tech 4
steedastangt battery relocation kit - need help SN95 4.6L Mustang Tech 2
Dean85GT Which battery relocation kit? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
Ronald_McDonald Battery Relocation Troubles Fox 5.0 Mustang Tech 1
G relocating battery.... Fox 5.0 Mustang Tech 1
B Battery Relocated...starting issue... Fox 5.0 Mustang Tech 20
D 2 gauge cable for battery relocation Fox 5.0 Mustang Tech 6
Bosko5.0 Battery wire relocation Inside Pic request! 1994 - 1995 Specific Tech 2
94GTLaserRC Battery Relocation Kit Questions 1994 - 1995 Specific Tech 35
R battery relocation...problem 1994 - 1995 Specific Tech 11
I Question about battery relocation kit.. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
0 Battery Relocate Engine wont turn over Classic Mustang Specific Tech 2
sleeperstang199 battery relocation pics???? 1994 - 1995 Specific Tech 2
A67StangMaster I am stuck... Battery Relocation Classic Mustang Specific Tech 16
