Battery Relocation Question
  • Thread starter Thread starter 87TurboMKIII
  • Start date Start date Feb 24, 2004
87TurboMKIII
29
  • Feb 24, 2004
I am planning to move the battery on my '83 to the rear to make room for the mass air conversion, and I was wondering if I could cut the terminals off the stock "hot" and "ground" wires and connect them to 0 gauge wire and run them to the back of the car through the firewall? Would I have any issues with the battery not charging or hard starts? I am just trying to look for a cheaper alternative to a battery relocation kit. Thank you for you help.
88POSLX
553
Red Deer, AB
Feb 24, 2004
  • Feb 24, 2004
No need. The positive just goes to the remote starter solenoid (I'm guessing your '83 uses one). So you just need to run the 1/0 gauge from the solenoid to the battery. And a ground is a ground so ground the battery somewhere in the back.
If you don't use a remote solenoid, then just run the positive from the battery to the starter.
However, keep in mind this is not track legal. You will not be allowed to ever make a pass down a 1/4 with it wired this way.
N
noslow5_0
422
dallas tx.
Feb 24, 2004
  • Feb 24, 2004
summit has them going for like 43 bucks right now... just a few more bones then what you may pay for 0 guage wire IMO....
87TurboMKIII
29
  • Feb 24, 2004
Where is the remote starter solenoid? Also, if I wanted to take it to the track what would I have to do? The battery on the '83 sits right where the airbox is on an '87-'93, that is the main reason why I need it moved. Thanx for the help.
tvmango
667
bradenton florida
Feb 24, 2004
  • Feb 24, 2004
I just did this,,, I bought the summit kit, remove the old positve and neg.. ran new positive from the solenoid to the back to the battery thought the firewall with wire loom on it... Ran down to autozone, got 3 more ground wires that where 24 inces long and had just the loops on each end.. went over to the pass side of the block and on the block, about 6 inches from the timing cover is the bolt that holds the starter wire bracket to the block, I took out that bolt cleaned it really good with sandpaper and put 2 of the 24 inch cables ends on it and bolted it back it.. I ran 1 cable to the sway bar bushing bolt that bolts to the frame, and one to the body where the strut tower bump is (cleaing off all the paint first),,
then in the back I ran the big bastard that came in the summit kit from the neg term of the battery to the wheel hop shock bolt that goes into the frame (cleaned first) ..... and the other 24 inch fro the neg term to the floor of where the spare tire goes ( again cleaned paint off first).. Worked like a charm....... tony
87TurboMKIII
29
  • Feb 24, 2004
So, where is the solenoid that I need to hook up the battery to?
tvmango
667
bradenton florida
Feb 24, 2004
  • Feb 24, 2004
where the posite wire form your battery goes know, that is your solenoid,, just remove and replace..
87TurboMKIII
29
  • Feb 24, 2004
Alright thanx. One more question. I bought the car used and the the previous owner has two wires, from the harness i think, hooked up to the ground battery connector on the end of the ground cable. Could i just leave the gorund cable hooked up and the two wires attached?
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
