Battery relocation
  • Thread starter Thread starter JBeezy53
  • Start date Start date Jan 27, 2006
JBeezy53
559
Sacramento, Ca
Jan 27, 2006
  • Jan 27, 2006
Basically to relocate my battery to the rear all I need is long positive cable and a short groung cable? Oh, and a tray?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 27, 2006
  • Jan 27, 2006
Rear mounted battery ground wiring. Follow this plan and you will have zero ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to the chassis ground where the battery was mounted up front. Use a 5/16” bolt and bolt down the 4 gauge engine to chassis ground, make sure that it the metal around the bolt is clean & shiny. This is the alternator power ground.
Crimp or even better, solder the lugs on the all the wire. The local auto stereo shop will have them if the auto parts store doesn't. Use some heat shrink tubing to cover the lugs and make things look nice.
The computer has a dedicated power ground wire with a cylindrical quick connect (about 2 ½”long by 1” diameter. It comes out of the wiring harness near the ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground in the same place as you bolted the alternator power ground. This is an absolute don’t overlook it item for EFI cars
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jan 28, 2006
  • Jan 28, 2006
He speaks the truth. haha
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jan 28, 2006
  • Jan 28, 2006
To be NHRA legal (so you can race at a track) you will need a sealed box usually (sometimes they will let you get away with no sealed box in a coupe) a on/off switch clearly on the outside of the vehicle that will shut off the car when swithed off, and a vent tube.
JBeezy53
559
Sacramento, Ca
Jan 28, 2006
  • Jan 28, 2006
Do you need a box at the track if you use an optima battery?
P
PRO50SC
1,012
Olney, Maryland
Jan 28, 2006
  • Jan 28, 2006
I've never had a problem. Places differ though.
JBeezy53
559
Sacramento, Ca
Jan 29, 2006
  • Jan 29, 2006
Thanks, I wasn't aware of the additional ground cable.
GearHd6
459
Ashford, CT
Jan 29, 2006
  • Jan 29, 2006
Good luck with installing the on/off switch. I'm still yet to figure out how to get the car to actually turn off when the switch is switched to the off position. It will kill the power to everything electrical but it wont kill the engine. I ran the seperate wire from the alternator back to the switch with a circuit breaker. That works for about 5 minutes until it overheats the circuit breaker and trips it. I heard you can put a diode in one of the alternator wires but I have yet to figure that out.
1bad92lx
247
Close to lynchburg, VA
Jan 29, 2006
  • Jan 29, 2006
To kill the engine the switch has to be in between the ignition switch and the engine. You have to kill the spark or the power to your ignition. Think of it this way, will a car start with the coil wire off? My buddy had his wired wrong to where he could flip the switch and it would stay running and he was denied any track time that day.
GearHd6
459
Ashford, CT
Jan 29, 2006
#10
  • Jan 29, 2006
  • #10
Yeah? So I need an ignition wire going back to the kill switch along with the positive battery cables?
GearHd6
459
Ashford, CT
Jan 29, 2006
#11
  • Jan 29, 2006
  • #11
I believe it also has to kill all electrical power to the car not just kill the engine.
JimBowy
330
Downriver, Mi
Jan 29, 2006
#12
  • Jan 29, 2006
  • #12
Here is what I suggest....
JBeezy53
559
Sacramento, Ca
Jan 29, 2006
#13
  • Jan 29, 2006
  • #13
The computer has a dedicated power ground wire with a cylindrical quick connect (about 2 ½”long by 1” diameter. It comes out of the wiring harness near the ignition coil & starter solenoid (or relay). This is an absolute don’t overlook it item for EFI cars
What does this wire look like? Colors?
mustangsally93
281
Omaha,NE
Jan 29, 2006
#14
  • Jan 29, 2006
  • #14
got pics? I want to do the same under the floor in the spare tire hole. If you guys can help me too. Couldn't find in anything in the search part.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 29, 2006
#15
  • Jan 29, 2006
  • #15
The computer
has its own dedicated power ground that comes off the ground pigtail on the
battery ground wire. Due to it's proximity to the battery, it may become corroded
by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1"
diameter with a black/lt green wire. You'll find it up next to the starter solenoid
where the wire goes into the wiring harness.
to figure that out.
For a battery cut off switch, see http://www.moroso.com/catalog/categorydisplay.asp?catcode=42225
is the switch http://www.moroso.com/catalog/images/74102_inst.pdf is the installation instructions.
Use the super duty switch and the following tech note to wire it and you will
be good to go.
Use the Moroso plan for the alternator wiring and you risk a fire. The 10
gauge wire they recommend is even less adequate that the stock Mustang
wiring.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/4" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug
there is a green wire. It is the sense lead that turns the regulator on when
the ignition switch is in the run position. Cut the green wire and solder the 40'
of green wire between the two pieces. Use some heat shrink to cover the
splices. See http://fordfuelinjection.com/?p=7 for some excellent
help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire.
Try to run the green wire inside the car and protect it from getting cut or
chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp
on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs.
Do not add the jumper between the 1/4" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green wire is the ignition on sense feed to the regulator. It supplies power
to the regulator when the ignition switch is in the run position. Turn the
Moroso switch to off, and the sense voltage goes away, the voltage
regulator shuts off and the alternator quits making power.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 88-90 wiring and lots more…
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Diagram courtesy of Tmoss and Stang&2birds.
GearHd6
459
Ashford, CT
Jan 29, 2006
#16
  • Jan 29, 2006
  • #16
Wow! Jrichker... Thats some awesome info. Thanks a lot, I appreciate the help. I've been trying to figure this out for some time now.
JBeezy53
559
Sacramento, Ca
Jan 30, 2006
#17
  • Jan 30, 2006
  • #17
Where's a good place to get the cables? I've looked all over the internet and they are expensive! I'll probably buy them from summit.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 30, 2006
#18
  • Jan 30, 2006
  • #18
See http://www.skycraftsurplus.com/ for the cable at a very reasonable price. Welding cable works good, it is flexible and comes in the right sizes.
JimBowy
330
Downriver, Mi
Jan 30, 2006
#19
  • Jan 30, 2006
  • #19
I just use my local welding supply store. Make sure whatever you do you get welding cable. You can thank me later when you realize how easy it is to work with.
GreatWhite
232
Fairfield, PA
Jun 30, 2006
#20
  • Jun 30, 2006
  • #20
I just got teary-eyed... saw my old s/n with the BANNED under it
so sad
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
New here
  • Foxbody209!
  • Jan 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 8, 2026
Foxbody209!
Engine Crankcase vent tube “relocation”?
  • Mcmahst
  • Nov 20, 2025
Fox 5.0 Mustang Tech Dec 20, 2025
manicmechanic007
