Basically to relocate my battery to the rear all I need is long positive cable and a short groung cable? Oh, and a tray?
90mustangGT said:To be NHRA legal (so you can race at a track) you will need a sealed box usually (sometimes they will let you get away with no sealed box in a coupe) a on/off switch clearly on the outside of the vehicle that will shut off the car when swithed off, and a vent tube.
I've never had a problem. Places differ though.JBeezy53 said:Do you need a box at the track if you use an optima battery?
jrichker said:Rear mounted battery ground wiring. Follow this plan and you will have zero ground problems.
The computer has a dedicated power ground wire with a cylindrical quick connect (about 2 ½”long by 1” diameter. It comes out of the wiring harness near the ignition coil & starter solenoid (or relay). This is an absolute don’t overlook it item for EFI cars
The computerJBeezy53 said:What does this wire look like? Colors?
For a battery cut off switch, see http://www.moroso.com/catalog/categorydisplay.asp?catcode=42225GearHd6 said:Good luck with installing the on/off switch. I'm still yet to figure
out how to get the car to actually turn off when the switch is switched to the off
position. It will kill the power to everything electrical but it wont kill the engine. I
ran the seperate wire from the alternator back to the switch with a circuit
breaker. That works for about 5 minutes until it overheats the circuit breaker and
trips it. I heard you can put a diode in one of the alternator wires but I have yet
to figure that out.
JBeezy53 said:Where's a good place to get the cables? I've looked all over the internet and they are expensive! I'll probably buy them from summit.
