battery
  • Thread starter Thread starter oldno7
  • Start date Start date May 19, 2010
O
oldno7
109
May 19, 2010
  • May 19, 2010
Should my positive and negative leads tone out on a continuity test. I checked 2 other battery's and they didnt tone out. I will take the battery back tomorrow and see what they say? Every one I ask at work are puzzled too. Yes I put/hooked it up right +red -black. Thats the first thing they asked me.
bullitstang1313
713
Indianapolis / Columbus, Indiana
May 19, 2010
  • May 19, 2010
I'm not exactly sure what you mean by "tone out" Are you saying that you have continuity between your positive and negative battery cables? If the battery is disconnected, you shouldn't have continuity between your positive and negative battery cables. Continuity between the two would indicate a short somewhere.
O
oldno7
109
May 20, 2010
  • May 20, 2010
yes the battery is out of. car and i have continuity at my battery cables.
O
oldno7
109
May 21, 2010
  • May 21, 2010
ok i went to autozone and told them it was a bad battery. They tested it and said it was fine. I told him it was bad and showed him the continuity test and it toned out. Grabed a new one and did a continuity test and it didnt tone out. So i said i want that one now that you can see this isnt right. So i got a new one now. But my ignition is bad and i have to fix it now this is going to be fun.
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
