Bauman Shift Kit
JD1964
there is enough sticking out to grab on to
3,427
1,518
194
Maryland
I had previously installed a Bauman kit in my AOD which I have now rebuilt. I need to adjust the WOT shift points to a lower rpm this time around but I lost the instructions. Does anyone have a set of Bauman instructions for AOD they can share with me?
Thanks for responding Mike. Although, that system in the link you posted is electronic control for AODE. I was looking for shift kit inst for AOD. I dug around some more and found the data chart I was looking for tucked in a Transgo box for a TH350 I had worked on. Here it is. In this particular kit you can raise or lower WOT shift points in the AOD by installing various spacer thickness on one of the valves. I haven't torn back into the valve body just yet. It will be a simple task once I get around to it.
