  • SN95 4.6L Mustang Tech
BBK 70mm throttle body problems!
  • Thread starter Thread starter shakenO2GT
  • Start date Start date Sep 4, 2006
shakenO2GT
12
  • Sep 4, 2006
Yesterday I installed a bbk 70mm tb, The problem I am having is when I rev the motor up and as the rpms come down it idles at 1200 rpms for about 4 seconds and then it drops down to normal idle below 1000. what do you think is wrong? could it be possible tps?
CobraRed_96_GT
1,421
UCSD/La Jolla
Sep 4, 2006
  • Sep 4, 2006
did you remember to install the return spring? or it could possibly have too much slack; it's job is to return the throttle position back to closed and it could possibly be leaving it open
- Does the throttle pedal feel solid or kinda weak and squishy?
P
Pennywise2
Banned
May 16, 2006
1,379
  • Sep 4, 2006
I bet their is too much slack that is causing the problems.It could have been put together wrong.
This is the first time I heard of anyone having problems
with BBK throttle bodys.
The throttle bodys I hear people were having problems
with were the Mac throttle bodys.
shakenO2GT
12
  • Sep 4, 2006
the pedal feels great and the car has better throttle response i guess it could be a defect in the part?
stangliter04
185
Port St John, Florida
Sep 4, 2006
  • Sep 4, 2006
I am having the same problem... my tuner said it has something to do with the blade not closing all the way. are you getting an enigine code? I am getting TPS voltage low
OV10stang
48
Pembroke, NH
Sep 4, 2006
  • Sep 4, 2006
Try adjusting the blade towards the closed position a little at a time, just make sure it doesn't bind. You have to have it running to feel if it's binding. The IAC will compensate. Did you disconnect your batt also like the directions say?
shakenO2GT
12
  • Sep 4, 2006
nope no code, I did disconect the battery and I let it idle till operating temp. I will try adjusting it.
GDawg
1,469
Nevada
Sep 4, 2006
  • Sep 4, 2006
My brand new MAC acted that way. The idle was slow to drop then it would stick on idle. When I would slowly press the gas on stop to go, it stuck till it broke open and would give too many rpms. I sold it brand new for a loss after two weeks. Accufab for $100 more has never given me a problem and it's still on for my supercharger.
hotdog71
427
Seattle, Eastside
Sep 5, 2006
  • Sep 5, 2006
Did you you buy it brand new or used?
Mine went on with out a hitch and I know a few other that have had 0 probs with the BBK installs.
If it new then the blade is factory set and should not be adjusted, you didn't clean off the sealant in side the TB did you? that will cause it to mess up too.
If it's new I would call BBK tech support and talk to them or send it back to where ever you bought it from and ask for a replacement.
Just my 2 cents worth.
I
ilbehaved
23
madison, ms
Sep 5, 2006
#10
  • Sep 5, 2006
  • #10
mine did it then i did that mod that u use the copper cap and drill a hole in it and its never done it since.
G
Gerardo
31
pasadena, tx
Sep 6, 2006
#11
  • Sep 6, 2006
  • #11
mine did the same, in my case it was the TPS, i forgot to put it the right way
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
