  • 1994 - 1995 Specific Tech
BBK / Elderock Throttle Body 70mm
  • Thread starter Thread starter boricuaitaliano
  • Start date Start date Jul 19, 2004
boricuaitaliano
39
  • Jul 19, 2004
Another Question for ya,
I recently installed a 70mm bbk/elderock throttle body on my 94 mustang gt and noticed my car is now idling high at 3 rpm's. Is there a reason why it would be doing that? Prior to installing the TB I installed a bbk fuel pressure regulator and had set it to 44psi.
thnx,
Joe.
GTJake
3,049
Ann Arbor, MI
Jul 19, 2004
  • Jul 19, 2004
Did you hook up the IAC and TPS the same way they came off? I know RIO was having this problem on his fox setup when the IAC was on backwards.
Jake
AznStanger3v
2,026
Northern VA
Jul 20, 2004
  • Jul 20, 2004
i dont see why it wouldnt pass.
boricuaitaliano
39
  • Jul 20, 2004
Someone told me it's probably because I am using 19lb injectors. I am not sure if thats true or he was trying to sell me somthing. If I get 24lb injectors, would my ****z pass smog?
boricuaitaliano
39
  • Jul 20, 2004
Just to be clear there is no such as 23lb injectors for a stang is there? I went to this place in Sacramento and sales dude told me I can only use 23lb injectors no more then stage 2 or my car would not pass smog.
Joe
slytherin
702
northeast ohio
Jul 21, 2004
  • Jul 21, 2004
He doesn't know his ass from a hole in the ground it's 24lb injectors, I believe there is an idle screw on the throttle body somewhere I haven't dealt with mine yet so I can't vouch for it's existence but I think thats what you are having issues with. let's see if the other guys know about this and can help?
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
