BBK lowering spring question
  • Thread starter Thread starter dw89lx
  • Start date Start date May 31, 2005
dw89lx
44
Boston, MA
May 31, 2005
  • May 31, 2005
Does anyone know which way the pigtail is supposed to face on the front springs? My springs are making alot of noise and its driving me crazy. I looked at the drivers side front spring today and the pigtail is facing the passenger side and it doesn't look right to me.
bigsparky
334
Saskatoon, Saskatchewan
May 31, 2005
  • May 31, 2005
There is a little notch in your a-arms.. the pigtail goes into this little notch
Are you sure it's the springs making the noise?? did you reconnect everythign? ie sway bar?
dw89lx
44
Boston, MA
May 31, 2005
  • May 31, 2005
I bought the car with the springs already installed. The front sway bar was also removed. The ball joints and tie rods look OK and the noise only happens when I hit bumps or pull in or out of the driveway. Is there a way that I can move the springs without taking the suspension apart?
04sleeper
2,674
14
89
Dallas, TX
May 31, 2005
  • May 31, 2005
No. The front springs are under a lot of pressure and you need to lower the A-arm to move them. Also put the swaybar back on and check the bushings.
Then double check the strut bolts.
Also jack up the front of the car and try to wiggle the wheel back and forth to see if there is any play.
dw89lx
44
Boston, MA
May 31, 2005
  • May 31, 2005
I'm in the process of getting a front swaybar and I've already checked for play by moving the tires. I haven't checked the strut bolts yet. Do I need to torque them down or just make sure the bolts are tight?
04sleeper
2,674
14
89
Dallas, TX
Jun 1, 2005
  • Jun 1, 2005
The bottom bolts should be torqued down to 140-200 ft. lbs. and the top nuts to 40-55 ft. lbs.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
Wheels-Tires Front fender & liner rub with 245/45/17s
  • FastDriver
  • Jun 21, 2024
2K
Fox 5.0 Mustang Tech Jun 24, 2024
Warhorse Racing
Suspension Rear driver side sits lower than rear passenger side...?
  • 91GTstroked
  • May 15, 2024
3K
Fox 5.0 Mustang Tech May 18, 2024
91GTstroked
