BBK LT install progress report: Day 1
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
well, not really day 1. I started last week. But i went to my mothers in Elyria Ohio for few days(to hook up with mossberg for little tranxtion). but i spent first few days looking for good write up and buying all the tools I need. and i'm damn near broke for buying tools i need, and i'm sure there is more i need:notnice:
Anyway, i'm using write up at fnsweet, and found few things that can be done without, or somehow not same as mine. for instance, on step 8, it tells u to use 24mm socket and 21mm socket to remove bigass bolts that holds strut to spindle. mine was for some reason or another, not 24mm.. but 7/8:shrug:. My bolts might have been changed in the past for some reason? who knows. anyway, i got that off. And to get ABS senser out, it use E8 torxs. And it stripped head like bolt are made of lead:mad:. I used vicegrip to get it off. i guess i need to replace bolt with something else. don't like torxs anyway.
fnsweet instruction also recommends you to take calliper and bracket off. and remove rotor. i haven't done that, as i could not get the darn 15mm bolts to loose with anything. so went ahead without taking them off.
u can get to everything(so far anyway) without rotor off. it would be easier to have it off. only thing is you have to push splash sheald away while your pulling cutter pin that holds tie rod end bolts( i just cut the f!@#er away. u should re-use cutter pin anyway), and u also have to push the sheald away to drop tie rod end after u remove it. i assume with rotor in place, it'll be heavy as crop to remove K-member. but i bought second set of floor jack. so it shouldn't be that big of pain.
So Tomorrow, i'm going to brace engine, and start taking off k-member. will see how bad thats going to be.
Oh and to those of you who wants to do this, but not too sure about if you can do this or not, so far, its not hard. its just time consuming, and use alot of elbow greas. once i start taking things apart, it took me about 3 hours to get driver side off, because its my first time. but passenger side came off much much faster. total time so far on actual wrenching part is about 5 hours. So if your wondering if you want to do this on your own, or pay someone to do it, stop wondering. because you'll spend some money on tools. but still going to be much much cheaper then paying mechanic to do it!!
here is pic. Driver side spring is just about ready to come off
kcast said:
i know a guy at meineke, he only charged me 200 bucks, other then that screw messing with all that suspension and crap
well, if you have a buddy who'll hook u up, by all means, go for it. I would if i have one of them. But since i don't, and i just like the fact i'm doing it by myself - make tighter bond between me and Jessie(my car). plus i hate to have someone mess with my car.
i just hope tomorrow would go as smooth(reletively speaking) as it was today.
I was told that you can do this with just one floor jack. I highly dought it. if u have Bill Goldberg as helper, i guess you could. Otherwise I can't see wiggleing K-member without jack or get it and out without it.
oh, if you installing LT, and you have chance to get your hand on small air compressor tank(like 10Gal ~15Gal about $150+), and inpast gun, I would highly recommend it!
