Well after a 20 hour or so battle with fitting the headers putting the springs back on and trying to get the oil dip stick tube back in I finally have the headers and h-pipe on. The car sounds sweet and I can feel some improvements in acceleration for sure. I did run into a couple of problems.
1. I could not get 2 of the bolts on on the passenger side header (top of header). I did use locking header bolts and I was able to get the locks on most bolts. All of the bolts went on just fine on the driver side. The passenger header is on there real tight and I don't think it will come off but will missing two bolts cause problems? (I couldn't find any obvious leaks)
2. I could not get the oil dip stick tube all the way back in its hole. It's just sitting in it a little bit and I hope it won't pop out...I'm going to look into getting the ones that you can bend but can I put this on smiply with the car jacked up?
I'm going to try to get under there this summer for those two bolts but until then I'll just have to keep my ears open which won't be hard because my car screams now
