bbk ssi
  • Thread starter Thread starter DURRETT
  • Start date Start date Jan 8, 2008
D
DURRETT
18
  • Jan 8, 2008
I am looking at buying the bbk ssi but haventt heard much does anyone know anyhting about them
I want to run it with 30lb injectors 76mm maf, 255 lph pump will it work or is there a better way to spend 1500
bloopbloob
578
Alberta
Jan 8, 2008
  • Jan 8, 2008
there have been a lot of people saying they've had problems with the bbk, like fuel leaks. you should be able to pick up all that stuff for around $1000 brand new! $550 for the SSI, ~$280 for injectors, $125 for the MAF, $130 for a 255lph.....
what other mods do you have? i'd say the money could be spent better elsewhere, but it really depends on what you have already....
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 8, 2008
  • Jan 8, 2008
Systemax
LiquidGT
368
Near STL hell
Jan 8, 2008
  • Jan 8, 2008
I researched it last year when I was looking for an intake, I heard of the fuel leaks. I think you have to use a BBK afpr with it, the others dont fit. One guy with a Cobra kit car had an internal coolant leak because of defective thin casting. A lot of people think it should have been a dual TB design to work efficiently.
D
DURRETT
18
  • Jan 8, 2008
i have arp heads
bbk intake
underderive pulleys
pro 5.0 shifter
short tube headers
h pipe
flowmaster
tach
so i thought it would be time to work on the fuel and air system any suggestions
85ragtop
BTW, I like dudes.
475
123
NC
Jan 8, 2008
  • Jan 8, 2008
There are a ton of threads on this. Search and see what you come up with.
bloopbloob
578
Alberta
Jan 8, 2008
  • Jan 8, 2008
what's a bbk intake? (only one i know of is the SSI???) also, you shouldn't need 30lb fuel injectors yet with those mods. and a larger MAF doesnt do much (if any) good if you're still running a stock TB
i highly recommend subframe connectors being your next mod!
ttop88
42
indiana
Jan 8, 2008
  • Jan 8, 2008
DURRETT said:
i have arp heads
What are these? I too love the look of the systemax, but it really needs a blower.
ttop88
42
indiana
Jan 8, 2008
  • Jan 8, 2008
I think he is refering to a cold air pipe. I agree on the injectors. Also agree on SFC's if the are not already installed.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 8, 2008
#10
  • Jan 8, 2008
  • #10
The BBK SSI is recommended for a 1500-6500 RPM powerband.
It has a 75mm throttle body opening and a built-in EGR spacer.
BBK-5001* 1986 - 1993 5.0L SSI Intake Manifold - $580
BBK-5002* 1986 - 1993 5.0L SSI Intake Manifold w/ BBK-1501 70mm Throttle Body - $760
Looks like a decent intake to me.
Like many new products, many are scared to try it and spend money on it.
stykthyn
5,232
2,652
223
gainesville
Jan 8, 2008
#11
  • Jan 8, 2008
  • #11
there have been quite a few people that have gotten past the leaks and quality issues and run the intake successfully. what really pisses me off is that no one will post any dyno pulls or describe how their car behaved after all the bugs were worked out. personally the design looks like it could flow pretty well and really wake up an engine, but all I hear is a bunch of haters that say it is crap straight from the box. Sure BBK should clean up the design and cure their quality probs, but how does a properly functioning intake perform on a healthy motor???? I wish I knew. I would jump at the chance to try one if I could find it at a decent price.
bloopbloob
578
Alberta
Jan 8, 2008
#12
  • Jan 8, 2008
  • #12
i like the look, and the fact you can take your VC's off with the intake still on. i almost bought one right when they came out, but i saw nothing but bad reviews, so i held off. it seems of late, that the quality has improved quite a bit, but i'm not in a position to be buying mods right now, but i think i'll give it another look in the future....
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 8, 2008
#13
  • Jan 8, 2008
  • #13
I do believe there is some excessive "hating" going on, and I think the intake is not to shabby.
Good reading on the BBK intake:
http://www.mustang50magazine.com/techarticles/m5lp_0603_bbk_ssi_r_intake/index.html
Some of the fuel leak issues I seen, seemed to be install error.
Sicarius428
2,085
Jan 8, 2008
#14
  • Jan 8, 2008
  • #14
DURRETT said:
i have arp heads
bbk intake
underderive pulleys
pro 5.0 shifter
short tube headers
h pipe
flowmaster
tach
ARP head bolts? I think you meant AFR right?
Kevin
C
clayschmuck
48
San Antonio
Jan 8, 2008
#15
  • Jan 8, 2008
  • #15
This is my issue with the intake:
Before I start, didn't this SSI Intake issue come up before and got shut down? Anyway, I strongly believe in customer service/support. A close friend of mine purchased the SSI intake for his '93 GT. He had the same problems that a lot of people had - fuel leaks. Mind you, my friend is no novice mechanic! When he called BBK to talk to their tech support, they basically said too bad. Well, he went through a buttload of o-rings and finally fixed his fuel leak problems. There were other fitment issues besides the fuel leaks.
Just so other's know, I'm not busting on BBK or their products. I have several on my Mustang and they work quite nicely. I was just a bit disappointed when they (the tech support) were so rude.
As it was stated above, I would love to see a comparison with this intake and others....it is a nice looking and unique intake!
My .02 cents
Clay
leroy93lx
29
Indiana
Jan 9, 2008
#16
  • Jan 9, 2008
  • #16
I think i have seen people call the ProComp heads ARP in other threads. I may be wrong though.
stykthyn
5,232
2,652
223
gainesville
Jan 9, 2008
#17
  • Jan 9, 2008
  • #17
from what I have read, the easiest fix is to modify the stock fuel rail to fit the new intake. I would then sell the BBK ones and make some mad cash on EBAY.
F
Fox8950
247
Jan 9, 2008
#18
  • Jan 9, 2008
  • #18
AFR makes heads, ARP makes fasteners (i.e. head BOLTS)
Y
BBK SSI Crossover tube
  • yaboity
  • May 17, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 7, 2025
yaboity
Y
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
