  • SN95 4.6L Mustang Tech
BBK Underdrive pullies
  • Thread starter Thread starter crazystang05
  • Start date Start date Apr 25, 2005
C
crazystang05
172
  • Apr 25, 2005
i just installed the underdrive pullies, that i have ahd for about a year. Everything went well except the crank pullie the actual pullie is fine its the stock dampner that is bolted to new pullie. When running the dampner looks like it wobles just a little bit, not much wondering if this is a problem and how i can fix it. car seems too run fine. thanks
40thGT
14
Jupiter, FL
Apr 25, 2005
  • Apr 25, 2005
I have the same question. I have UPR's and the pulley itself looks ok, but the dampener does wobble slightly. I went as far as driving it for a month, then taking it off and re-installing it. Still wobbles.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Apr 26, 2005
  • Apr 26, 2005
The Steeda Underdrive pulleys would be a
better choice in my opnion for the 4.6L .
babeabe19
77
SAC TOWN
Apr 26, 2005
  • Apr 26, 2005
yea it is a problem eventually (if it hasnt happend already) it will weaken your front crank seal. did it to mine untill i got smart and ordered myself a set of steeda's. after i had to replace the seal.
C
Chopper1
91
Wv
Apr 26, 2005
  • Apr 26, 2005
Never run piggyback pulleys.
OUR01GT
121
EAST CENTRAL OHIO
Apr 26, 2005
  • Apr 26, 2005
I have had no trouble with the BBK's. They do not wobble and everything lined up and runs true.
yellowstang1994
338
  • May 4, 2005
I have a 5.0 and I don't know how much different your balancers or dampeners are from the 5.0L engine. However, the balancer is going to wobble a lot because thats what it does, dampens. Even if you install a new one you will experience the same thing. When you need to worry is if the rubber seal is coming out of the dampener, or is starting to come out. It will throw off the balance and you will experience a vibration. But if you aren't and everything is fine, don't be alarmed by the dampener wobbling behind the pulley.
BABstangV6
Smater than the average bear!
Apr 3, 2003
595
Rock Hill, SC
Jul 14, 2005
  • Jul 14, 2005
I just bought some BBK Underdrive pullies, so your guys advice would be just to sell them and buy some Steeda ones?
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jul 14, 2005
  • Jul 14, 2005
propellerhead
1,541
"but what's with the but shots?"
Jul 14, 2005
#10
  • Jul 14, 2005
  • #10
I've read articles about harmonic vibration that would advice against replacement pullies. They say that the aftermarket pullies do not have the same vibration dampening qualities as the stock ones do.
*shrug*
This is one reason I chose not to get UDPs. Too many conflicting accounts. Too little gain to justify the risks. But that's a personal choice...
KronicRacer
502
puttering around Ft Lauderdale, FL
Jul 14, 2005
#11
  • Jul 14, 2005
  • #11
if thats the case how bout also throwing on a new harmonic dampner when you do the udp's?
Engine Underdrive pulleys
  • Mindseye007
  • Feb 1, 2026
Fox 5.0 Mustang Tech Feb 14, 2026
Willybill32
Help. 1968 engine swap to 95 5.0
  • superdog68
  • Jun 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 23, 2025
Mcmahst
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
